Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Mach Plasma / Laser
Old 11-20-2011, 12:02 PM
rbocaz is on a distinguished road
PMDX-122...which THC?
I have my DIY plasma cutting system. I've been cutting for more than a year, but I always find the problem when the sheet metal is wrapped. So I decided to upgrade to a THC system. My problem is I don't know for sure which THC to use, so I can keep using the existing BOB PMDX-122.
Any advice, experience is welcome.
Rick
Old 01-28-2012, 05:33 AM
claudiu is on a distinguished road
THC options
I`m in the same situation.
You can choose from Cand, Proma and Agelkom.
Another MM`er is mounting an Agelcom device, I chose Proma, so we can compare future experiences. Proma seems to me a very simple system to control your height setting up the desired voltage parameter. We will see!?
Cand sells only two Set`s, so it up to you.
Old 01-28-2012, 12:34 PM
I chose candcnc but my plasma machine doesn't work very much with the candcnc hardware.
Old 02-18-2012, 06:34 AM
stirling is on a distinguished road
if you use a powermax cutter this may be another option to those already mentioned.
Old 02-18-2012, 08:31 AM
asuratman is on a distinguished road
wow so expensive! is that stand alone?
Old 02-18-2012, 08:32 AM
Maybe you should contact Torchead candcnc and ask what to do.
Old 02-18-2012, 10:07 AM
Originally Posted by asuratman View Post
wow so expensive!
Huh???? how do you figure that out?
Old 02-18-2012, 10:43 AM
I did not know exchange rate, then I found it cheap after I read forex. Sorry.
Old 02-18-2012, 11:54 AM
shame you didn't checkout exchange rates BEFORE you dissed it. It's hard enough making a living these days as it is.....
Tags
thc
G203V and PMDX 134 swaggs21 Gecko Drives 10 04-18-2011 09:26 PM
PMDX-125 or PMDX-132 for Geckos? Nivea Gecko Drives 0 03-24-2010 02:18 AM
PMDX-122 and Mach3 ranchak Mach Mill 0 01-23-2010 02:56 PM
Problem- GECKO W/202 AND PMDX 131 glengen3 Gecko Drives 0 05-04-2008 05:00 PM
Mach3 + PMDX-122 Burn Mach Software (ArtSoft software) 0 01-06-2008 02:33 PM
