Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Mach Plasma / Laser
Old 11-08-2011, 08:09 PM
router101 is on a distinguished road
plasma cad software for mach3
Hi I have just bolted together an NC Rail plasma cutter and Mach 3.
It works ok and it will run the cut arc wizard g code file ok.
What do you recommend as an inexpensive cad program for simple
text and shapes? I need something that adds the cut on off type commands.
This is my first attempt at plasma cutting, have built and run a couple of cnc milling machines.
Old 11-22-2011, 10:32 AM
TAProwler's Avatar
TAProwler is on a distinguished road
Any CAD You Want - But SheetCAM for CAM
That is such an open ended question that it is hard to answer.
There are about a gazillion CAD software programs out there to pick from. The costs range from freeware (that are pretty capable) to spending $25K on something that will also butter your toast in the morning.
I won't make a suggestion on this, but I will offer this:
DO NOT get involved with BobCAD-CAM, period. Trust me on this one.
When it comes to CAM software for 2.5D stuff (including plasma) THERE IS NO EQUAL to SheetCAM!! It will cost you a few buck once, but Les is absolutely unbelievable. His product is awesome and he is fantastic when it comes to customer service and support. He will customize a post processor for your machine, whatever you need (if he doesn't already have it done) - and it will work.
Good Luck,
R/Todd
Old 12-10-2011, 08:33 AM
Mike 1948 is on a distinguished road
I agree, Sheetcam is great! As for cad software give Draftsight from Solidworks a look, its FREE and exports DXF files that play well with Sheetcam.
Mike
Old 12-13-2011, 02:42 PM
Arthurmetal is on a distinguished road
I agree also on Sheetcam, absolutily fabulous. My technical work runs from Turbocad to Sheetcam to Mach; for my artistic work I use CorelDraw through DXFtools to sheetcam to mach. Most of my time is lost on fixing drawings and files for the next step; polylines not closed, almost invisable artifacts somewhere in the drawing and such. Sheetcam does a teriffic job in exposing them but it takes a lot of time go to back and forth to fix them all. Maybe it is not the cad or whatever program that matters but the way they work together.
regards, arthur
Need Help!- mach3 plasma help BuiltByBrooks Mach Plasma / Laser 4 11-13-2011 12:07 PM
Differences Between Mach3 Mill and Mach3 Plasma? cjjonesarmory Mach Plasma / Laser 0 11-18-2010 09:12 AM
mach3 plasma restart mid-job? johnt Mach Plasma / Laser 2 12-03-2007 10:59 PM
Mach3 Plasma G41 G42 CARLES Mach Plasma / Laser 4 07-25-2007 05:08 PM
Mach3 Plasma anthony Mach Plasma / Laser 1 05-18-2005 06:21 PM
