Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Mach Plasma / Laser
Old 10-11-2011, 10:59 PM
MAS MAS is offline
MAS is on a distinguished road
Question Erratic Z-Axis
I have a problem with my plasma cutting machine that I can't figure out what's causing it.
When I run a cutting program with my plasma torch on and cutting the Z-Axis DRO reads erratic, up & down readings and the Z motor does not respond to this.
When I run the same program with the plasma off the Axis is rock steady as it should be. X & Y work perfectly with the plasma on or off.
What could possibly cause this?
My setup is: CandCNC MP3000 & 4 axes driver box with Applied Motion 3540M drives. (Flashcut 3.5amp microstep box)
hypertherm 1650 Plaz cutter.
Need Help!- X axis works fine but Y axis direction is erratic swampbud1 DIY-CNC Router Table Machines 4 12-06-2010 05:28 PM
Erratic Z axis action Sky Gazer Chinese Machines 4 10-04-2010 10:30 PM
erratic z axis endgrainguy General Electronics Discussion 1 11-12-2009 09:51 AM
Erratic CNCzone? CNCadmin CNCzone Site News and Contests 4 09-11-2007 03:24 PM
Erratic step signal? Tim Montzka Machine Problems, Solutions , Wireless DNC, serial port 0 07-31-2006 04:02 PM
