Results 1 to 3 of 3
Thread: Using Mach, can set the feed rate to what I want
    Registered Apples's Avatar
    Feb 2004
    Australia, Queensland
    I have downloaded the Mach 3 demo and can't get the actual feed rate to what I want. The set feed rate is much higher than the actual feed rate.
    Is this limited becasue it is a demo?
    Cheers
    Peter
    Mar 2003
    Shelby Twp, MI....USA
    Do you mean the machine can't go as fast as you want, or the displayed feed rate is too slow.
    If the latter, just add the feedrate to your g-code, ex: F50
    Put it in the first line before motion starts.
    The demo has no limitations.
    Unless you're talking about motor tuning. If that's the problem, the demo is limited to 25000 steps per second.
    Feb 2004
    hh
    Quote Originally Posted by Apples
    Cheers
    Peter
    It is limited to 1000 lines of code; then it just stops at 999; hehehe
    Better shoot Art the 160 bucks
