Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Mach Plasma / Laser
Old 07-26-2005, 02:37 PM
CNCadmin's Avatar
Site Owner
CNCadmin has disabled reputation
Running Mach3 for laser cutting questions
Ok here is what is working for me, I'm using the z to turn on and off the laser BUT I have one problem. When the file is done cutting and I hit the go to zero the laser turns on, of course I know why because it's Zing down to zero which turns the laser on.
How can I get the head to go to the home position after it's done cutting instead of just sitting there?
Thank You,
Paul G
Site Owner-Webmaster-
Administrator
www.rfqwork.com
www.cnczone.com
www.welderzone.com
Old 07-26-2005, 02:58 PM
ger21's Avatar
Add G0 X0 Y0 at the end of your g-code. You could also make a button on the screen with the code to do it. Don't ask me how, though.
Old 07-26-2005, 03:01 PM
CNCadmin's Avatar
Site Owner
That's the sames as the "goto zeros" in mach right? that's the problem in doing that the z move to zero which in moving in the down postion and that will turn the laser on which is what I don't want, I need it to just move to home with-out moving the z.
Thank You,
Paul G
Administrator
www.rfqwork.com
www.cnczone.com
www.welderzone.com
Old 07-26-2005, 03:09 PM
ger21's Avatar
Don't put a Z in the line. Just G0 X0 Y0
Old 07-26-2005, 03:10 PM
ger21's Avatar
What are you using to make g-code? You should be able to automatically add it to every file.
Old 07-26-2005, 06:53 PM
turmite is on a distinguished road
Paul I am pretty sure you can take care of this problem in screen designer by opening the 1024.set file and editing the go to z's button. Double click on that button and it should show you what is being called by the program. there may be more than one way to do this, knowing how Art makes this program as universal as possible.
Mike
No greater love can a man have than this, that he give his life for a friend.
Old 08-30-2007, 06:00 PM
mikegaylor is on a distinguished road
Thumbs up
Hi All,
I have mach 3 running a laser fine I use the spindle PWM output to vary the laser power this seems to work great. I also set the Mach to 2D mode. I think this may be your problem.
Please post comments on our forum if you need help as I'm only poping in here and may not reply. Thanks
Best Regards
Mike Gaylor
Old 08-30-2007, 09:08 PM
Mongkol is on a distinguished road
Laser
Hi All,
Mach3--> Laser--->Vector is good
Laser---> Raster is bad
Cheers,
Mongkol
Old 09-06-2007, 06:41 AM
dinnox is on a distinguished road
how tu cut in moshidraw
hi all i bought 40watt chines machine its work nice for engraving but i dont know how to cut.its run on moshi draw.can any one halp me.how to use cutmode in moshidraw.
regards
dinesh gajjar
Old 09-14-2007, 11:34 PM
sunmix is on a distinguished road
Good day, Mike Gaylor,
How do you configure the spindle PWM for laser output? What are the settings involved in tuning the PWM spindle? How does it tune the laser; by g-code or by manually pressing the buttons located in the spindle section? Thanks in advance =)
sunmix
