Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Mach Plasma / Laser
Old 10-06-2010, 12:13 PM
woodman08's Avatar
woodman08 is on a distinguished road
torch on/off commands
could someone post the torch on off commands contacts that mach3 requires to be hooked up also is it an M command in the code
Old 10-15-2010, 04:45 AM
chawkiz is on a distinguished road
hello also waiting for replay to control torch on off
and wats about this relay board
Old 11-03-2010, 05:52 PM
Torchhead is on a distinguished road
Plasma uses M03 for torch on and M05 for torch off. In MACH you "map" certain M commands to certain MACH ouputs (set in the Ports 7 Pins/Spindle Setup tab).
Once you map M03 to an Output (say Output 1) you then have to map in the ports and pins which PHYSICAL output (port and pin) it actually talks to. On a conventional BOB and parallel port the outputs available for relay or ON/OFF control are 1, 14 , 16 and 17. Those a re actual physical pins on the parallel port so you use a BOB to physically access those pins. A typical set may have M03 and M05 mapped to output1 and output1 is mapped to port1 1 pin 14. The polarity of that output when it's activeis defined in the Active Low column (you can make it go high for active or low for active. The parallel port pins have little current drive capability so typically you need some form of buffers to interface to increase the drive.
Since everything in MACH is defined by the "Profile" (XML) your settings when changed get stored in the profile.
Tom Caudle
www.candcnc.com
Old 11-03-2010, 06:03 PM
woodman08's Avatar
torch
thanks this helps
Hand torch to machine torch matttargett4 Hypertherm Plasma 10 06-01-2010 03:37 PM
hypertherm 1000 hand torch to machine torch duraflap Hypertherm Plasma 4 05-18-2010 02:34 PM
Need Help!- Different between hand torch& machine torch ltran2000 CNC Plasma and Waterjet Machines 7 03-02-2008 09:19 AM
G2 and G3 Commands Bohemund G-Code Programing 19 05-28-2007 09:12 AM
