Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Mach Plasma / Laser
Old 07-13-2010, 08:58 AM
woodman08's Avatar
woodman08 is on a distinguished road
mach3 parallel port or USB?
will mach 3 work with usb,noticed when i downloaded it that there was no mention of usb
Old 07-13-2010, 10:50 AM
ger21's Avatar
Only with an external motion device with a Mach3 plugin. Either the KFLOP or Kmotion from http://www.dynomotion.com/ or the Smoothstepper from www.warp9td.com
Normal operation of Mach3 without additional hardware is parallel port only.
Old 07-13-2010, 12:17 PM
woodman08's Avatar
flashcut
the plasma machine is run right now via flashcut and i would like to try mach 3,but the system is run by usb and i wasn't sure if mach3 has a usb input
Old 07-13-2010, 04:20 PM
ger21's Avatar
You can't use a Flashcut controller with Mach3, if that's what you're asking.
Old 07-13-2010, 04:27 PM
woodman08's Avatar
ok
Thats exactly what i am asking ,we're not happy with flashcut so it hought we would try mach3 but you have corrected that ,saves me wasting my time .Thanks a lot .
The only way mach3 is going to run this machine is to bypass the flashcut electronics and wire the 2 drives to a breakout board then to parallel port which is a lot of work.Thanks again
stan
How to add a second parallel port in mach3 waleed alhadidi Mach Software (ArtSoft software) 2 05-29-2010 09:45 PM
Need Help!- Mach3 on Laptop without Parallel Port Deviant Mach Software (ArtSoft software) 8 08-31-2009 07:34 PM
Need Help!- Mach3 Not Working At All With Parallel PCI Port Brenck Mach Software (ArtSoft software) 3 07-14-2009 07:43 PM
parallel port or parallel universe bruno34 Taig Mills & Lathes 5 04-15-2009 10:58 AM
Mach3 and Parallel port Me2 Mach Software (ArtSoft software) 4 01-28-2007 04:38 PM
