All Z measurements are from Z zero (Top of Material). Since that changes as the material wraps and moves from cutting, you have to reestablish Z zero often while cutting (before a pierce move) THC Corrections just prevents the Z from moving past preset limits. Min should be the lowest you will let the Z go while cutting. If you touch-off and reference on a high spot then proceed to cut to a lower spot and you have the MIN set to .2 then it won't follow the material down. The MIN should be 0 or perhaps even slightly negative. I set mine to -.125 for most cutting. It's just a failsafe so if you were to plunge off the side of the material, the Z would drive down as far as Z would go and possibly hit a grid bar and snap off the end of the torch. It's less concern on THC's that have the Dynamic anti-dive like the MP3000-DTHC and as I understand, the THC301D. The anti-dive would sense the voltage spike from the open cut and lock Down Movement. We have that as one of the CUT PROFILE parameters as a percentage of preset volts and is adjustable by the user. We found the number needs to change for thicker material.
TOM caudle
www.CandCNC.com
Totally Modular CNC Electronics.
LinkBack URL
About LinkBacks
