Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Mach Mill
Old 02-20-2010, 06:31 AM
umarcnc is on a distinguished road
Thumbs up Servo Drive Card for Mach II / Mach III
ello Dear Friends
Currently i have Brideport Series II CNC machine with Mach II installed in it.
The Servo Drive Card in the machine are locally made but i am NOT satisfied with their performance.
I am looking for some reliable SERVO DRIVE CARDS/UNITS , which i can run on Mach II or Mach III.
Best Regards
Umar Karim
Old 02-20-2010, 07:30 AM
H.O H.O is offline
H.O is on a distinguished road
It depends on what voltage and current you want/need for your particular motors. Here are a couple of links:
Granite Devices VSD-XE, drives brushed and brushless motors at <160V and 40A peak.
GeckodriveG320, G320X & G340, all <80V, 20A brushed DC drives.
CNCDrive has two drives, one <80V, 20A and one <160V, 35A.
Larken Automation, two models, <95V/12A and <170V/20A
Semis in Bulgary has a range of servo drives and amplifiers, all the way up to 200V/50A peak.
All of the above take step & direction directly from Mach3. There are more manufacturers and models out there but these are the ones I can come up with at the moment that takes step and direction.
Old 02-21-2010, 02:37 AM
thanks alot , i will check these sites
Help! Mach 3 with PCI parallel card. noyloj Mach Software (ArtSoft software) 9 12-23-2009 12:55 PM
Techno Servo controler card Vs Mach 3 Pplug Controller Cards 9 03-31-2009 08:57 PM
Can MACH generate +/- 10V to control SERVO spindle Drive? cjchands Mach Software (ArtSoft software) 2 07-22-2007 09:58 PM
Confused: Mach Turn, Mach Mill, Mach 2/3 ? CanSir Mach Software (ArtSoft software) 5 02-16-2007 04:41 AM
