Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Mach Mill
Old 02-12-2010, 05:08 PM
kvom is on a distinguished road
Question Mirror Parts
I have several parts to make in mirror pairs. In reading the Mach3 manual I read that setting the Scale on a DRO axis to -1 means all readings are in the opposite direction. Does this mean that I can use the same g-code program to make a part's mirror by setting the scale of either the X or Y axis to -1?
I assume the G2/G3 words would need IJ rather than R format, but that's not a problem. However, the program would need to scale those values as well as the X or Y.
Does the scale function allow me to reduce/enlarge a part overall?
Old 02-12-2010, 06:19 PM
ger21's Avatar
Yes, it should. Although there may be some issues with arcs, but they may gave been fixed in a recent version.
Mirror finish steel and aluminum parts vibratory bowl? Toggle Metal Finishing and Plating 1 01-06-2011 07:06 PM
I want that mirror finish CORBIN92087 General Metalwork Discussion 3 09-12-2009 11:11 AM
mirror image cp465vw Machines running Mach Software 8 04-13-2009 10:39 PM
mirror image blouie Esprit 5 12-24-2007 01:24 AM
Mirror - is this a bug? LongRat SheetCam 0 10-11-2007 12:48 PM
