I just installed a new BOB and G203Vs on my BP. When I move the table or quill in any direction the DRO reads more than the actual movement. I've made sure that I am in inches. My steps are the same as before I made the conversion (1000 steps). I'm pretty much at a loss as to what to look at next. Thanks, Ron |
| Is the actual movement correct? If not, you're steps per unit is wrong.
| Definitely make sure that you microstepping is factored in correctly to you calculation. I had the same problem. I use a Gecko G540. Multiply TPI*(microsteps per step)*(steps per revolution)*(revolutions per inch)= steps per inch. In most cases, the steps per revolution is 200. For my machine, my total steps per inch is set at 4000. (10 TPI)*(10)*(200)*(2)=4000. You probably already used this formula, but in case you didn't, there it is. |
| Just IN- All high-flex cables are not created equal | igus | Product Announcements & Manufacturer News | 0 | 05-11-2009 09:12 AM |
| Help with equal spacing | MegaMoog | EdgeCam | 0 | 06-03-2007 08:45 AM |
| G54 and tool offsets to be equal | Jedi | Mastercam | 5 | 05-17-2007 10:34 AM |
| Are all riser blocks created equal....... | jstarnes | Bridgeport and Hardinge Mills | 1 | 02-01-2007 03:27 PM |
| How Does One Get the Machine Scale to Equal Mach2' | TheNigerian | Machines running Mach Software | 5 | 05-08-2006 03:03 AM |
