Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Mach Mill
Old 01-23-2010, 02:56 PM
ranchak is on a distinguished road
PMDX-122 and Mach3
I just installed a PMDX-122 and G203Vs. I'm not really sure of the pins and ports settings that I should be using in Mach 3. I did setup the charge pump on pin 17. Also I setup the X,Y and Z Axis as shown in the manual. I have no movement and I'm not sure if there is another setting that I missed OR if there is an old setting from my previous BOB that I need to remove. Mechanically and electrically I can work things out, but the software side I'm lost. Thanks, Ron
Problem- GECKO W/202 AND PMDX 131 glengen3 Gecko Drives 0 05-04-2008 05:00 PM
Mach3 + PMDX-122 Burn Mach Software (ArtSoft software) 0 01-06-2008 02:33 PM
Making a Relay with the PMDX-122 Burn General Electronics Discussion 0 03-27-2007 09:02 PM
Last minute purchasing decision- PMDX-122 Burn Benchtop Machines 0 03-15-2007 03:11 PM
PMDX-122 BrakingBoard and MSD980 Driver Goose80 Servo Motors and Drives 1 02-16-2007 04:58 PM
