I've been reading up on how to limit the Z axis, so that Mach3 does not cut into the table. I'm now thoroughly confused between the uses of the term "limit". I understand hard and soft limits, and that they tend to be implemented to shut the machine down when reached. I thought that Mach3 offered a facility where you could specify a cut-off point in the Z axis, so that regardless of GCode instructions, the tool would not cut any lower than this set point. More importantly the machine would finish the cut, rather than shut down if this limit was reached. Is this the case, or do I have it wrong? Steve |
| Possible the Z Inhibit? I don't know how it works, though. One thing you might want to do is to check the program limits when you load your g-code. The -Z limit DRO will show how deep the cuts will go.
| Newbie- BF20 Machining underside of X table | bladehunter | Benchtop Machines | 4 | 11-30-2009 04:26 AM |
| Need Help!- Trouble machining solid with BCC 21 & Mach3 | hecirp | BobCad-Cam | 15 | 11-06-2008 06:33 PM |
| Mach3, G100 and an XY table. | Golden1ce | Machines running Mach Software | 3 | 05-27-2008 09:34 AM |
| Using mill table manually,, mach3 DRO readout | TheDude | Hobbycnc (Products) | 8 | 03-15-2008 05:03 PM |
| Anyone running Mach3 with a DynaCNC table top? | CrashMasterKev | Machines running Mach Software | 1 | 11-21-2006 08:36 PM |
