Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Mach Mill
Old 01-04-2010, 05:10 AM
kasari is on a distinguished road
mach 3 and the jgro machine.
Hello.
I just got my machine running and I'm trying to set it up but I'm an idiot.
After going through the motor tuning stuff, I still dont understand why I can jog an axis 1 inch but mach3 says 4.243.
I have 1/4 motor shaft and 1/2-10 lead screw. Can anyone help me please?
Old 01-04-2010, 06:33 AM
TOTALLYRC is on a distinguished road
Setting the steps per inch.
Originally Posted by kasari View Post
Hello.
There are a lot of things that can mess this up.
The easiest way to do this is go to the settings page and at the lower left hand corner is a button that says set steps per unit.
Make sure you are in either inches or mm before you set the axis.
On the main page make sure your scaling is set to 1. this is to the right of the dro's.
Mike
Old 01-04-2010, 07:15 AM
ger21's Avatar
Your steps per unit should be 2000 x microstepping amount. 8000 for 1/4 step, 16000 for 1/8 step, 20,000 for 1/10 step (gecko).
I'm guessing it's set wrong.
Old 01-04-2010, 08:25 AM
1/2 microstepping
Thanks guys, I`m useing 1/2 microstepping so does that mean my steps per unit should be 1000?
Do I put this in the motor tuning page also?
Old 01-04-2010, 10:15 AM
ger21's Avatar
4000. I thought I should have worded it differently. 1/2 steps doubles your steps, so multiply by 2.
Yes, you need to put that in the motor tuning for each axis.
ger21's Avatar
DeadTom's JGRO machine DeadTom JGRO Router Table Design 19 11-01-2009 02:50 AM
New Machine Build- Another JGRO machine......:) mlabruyere JGRO Router Table Design 17 10-10-2009 02:10 AM
First Machine -JGRO wallyh JGRO Router Table Design 39 03-18-2007 06:46 PM
JGRO Design OK for First Machine wallyh JGRO Router Table Design 7 07-15-2006 08:43 PM
Jgro router as a 4/5 axis machine mrbaseball JGRO Router Table Design 7 11-05-2005 01:22 AM
