Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Mach Mill
Old 12-22-2009, 11:46 PM
Larken is on a distinguished road
BOB design question about spindle
I'm designing a new BOB that has dedicated outputs and inputs layed out for the functions (4)step/directions, charge-pump, 2 aux outputs for Mcodes, spindle speed 0-10v and spindle-on.
But i would have to sacrifice 1 aux out to use as a spindle-on line(not enough outputs), so i made it that if there is a pwm output signal >1% on the 0-10V (and charge-pump ready) then it signals spindle-on relay.
Does anyone else do it this way or do all use a port output line to turn on the spindle ?
Larry K
Manufacturer of CNC routers and Viper Servo Drives
www.LarkenCNC.com and www.Viperservo.com
Old 12-23-2009, 02:52 AM
TOTALLYRC is on a distinguished road
Larry K
Hi Larry,
Doing it you way how would an M05 (spindle stop) in the gcode stop the spindle.
I guess you could just program S0 but then how would you get spindle reverse. Not everybody uses reverse but I am not sure if you want to make a product that doesn't allow "standard" G-code control
Since you have 0-10v analog output I can assume we are talking about VFD or dc motor control. The way that I am familair is to have 1 pin for forward, 1 for rev and neither on for stop. YMMV.
Mike
Old 12-27-2009, 06:52 PM
Good point, maybe i will make it jumper selectable to use a dedicated line for spindle on as well.
It will have 2 other outputs that can be used for spindle reverse, coolant, mist etc.
I wonder how many people actually use a charge pump signal ?
Newbie- Some Spindle Design Questions Curtis_F General Metal Working Machines 29 07-09-2009 04:29 PM
Spindle design (R8 + Tormach TS) ticica Mechanical Calculations/Engineering Design 6 02-06-2009 05:28 PM
spindle design resources dagray3 Mechanical Calculations/Engineering Design 18 11-29-2007 04:56 PM
Spindle design? ever been tried? Kipper General Metalwork Discussion 14 08-31-2006 05:41 PM
Let's design a spindle! Cold Fusion General Metal Working Machines 71 11-21-2004 03:30 PM
