Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Mach Mill
Old 12-22-2009, 04:08 PM
jking is on a distinguished road
spindle control??
HI all I am about to give up on this whole cnc thing..Just too overwhelmed.
I am trying to connect an ac drive to be controlled by mach. I had the steppers working. My kid borrowed my computer for a day. I put it back in the shop but forgot to connect the dang serial port plug!!! I was configuring the ac drive to run remote and thought I had the wires correct. I couldnt get ANYTHING to work!! Boy how stupid I am.Anyway, I removed the wires and messed with pin settings before I figured out what was wrong..Dang dang dang....
Well back to my question. Is there a way to start the spindle without g code?? I dont see any switch on the Mach control screen.I just want to see if I have the ac drive wired correct this time. Excuse me if this is elementry but Im still in kindergarden! Lol...thank jim
Old 12-22-2009, 06:17 PM
TOTALLYRC is on a distinguished road
There are 2 ways. On the keyboard the F5 key will toggle the spindle on and off. If you have the spindle wired to accept S commands and the drive ahs a minimum speed of zero, all the F5 key will do is turn the internal realy to on but may result in no spindle movement.
The other and possible better way is to go to the MDI page ALT-2 is the keyboard short cut.
High light inside the MDI box. type M03 S1000 and the spindle should go in the clockwise direction at a speed of 1000 rpm if all is wired and you have it wired to accept S commands from the PC. M05 to stop. M04 to go in reverse.
Mike
P.S. Never let anyone borrow your CNC computer. I think that is the second deadly sin.
Mike
Old 12-22-2009, 07:18 PM
Thanks Mike!
I really havent figured out the ac drive bob switches yet.trying to understand how the switches are connected thru the bob then to the ac drive.Really tuff for the electrically challenged for sure! Thanks again. Jim
PS. they took my puter again tonite. Gotta get theirs fixed!
Old 12-22-2009, 10:58 PM
Glad I could help,
Keep us posted.
Mike
spindle motor and spindle control dont work customcncparts Milltronics 0 10-01-2009 02:08 PM
Spindle control? LeeWay General Metalwork Discussion 17 05-29-2009 04:06 AM
Can't control spindle Mark Jackson LinuxCNC (formerly EMC2) 3 11-05-2007 10:34 AM
Using Flashcut CNC Spindle rotate card control to control laser power pyroplotter FlashCut CNC 0 10-15-2007 09:46 PM
X3 spindle control Jed Benchtop Machines 5 06-01-2007 11:10 AM
