| Hi - I need to have a "CYCLE START" push button instead of having to use a mouse and click on the "CYCLE START" button on the monitor. Any one have a fix for this problem or where I can go to get info. I am using the software and stepper motors to run a machine other than a cnc mill. So I have to run a cycle, load the machine and run another cycle. |
| Just connect a button to an unused input pin. You assign an OEM Trigger to it in ports and pins.
| Rick, I have attached a few jpgs to explain the procedure. 1: Assign the port and pin to OEM code 1 2: Assign OEM Code 1000 to Trigger 1 3: Attach switch to appropriate pin on your breakout board "in the example pin 15" 4: finished. Hope this helps, Jeff....
__________________ Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish. |
| Jeff, I think you need to also set the hotkey for the OEM trigger to match the cycle start hotkey. Right?
| Gerry, I have set it up without the hotkey and it works fine however I guess you could add the hotkey code "2162" Jeff...
| I don't think you can type the code, you actually have to hit the key. But if it works without it, then no need to. I didn't look at the secind image you posted. Setting the OEM code apparently does the same thing as setting the Hotkey. Thanks for the clarification.
Thanks for thinking out this one. I updated to a touch screen, instead of adding a button. Still really need the button though. ![]() Added the button. Dry dusty fingers no good on touch screen. Thanks Jeff!!
__________________ Super X3. 3600rpm. Three ways to fix things: The right way, the other way, and maybe your way, which is possibly a faster wrong way. Last edited by neilw20; 12-04-2009 at 07:08 AM. |
| Neil & Rick, You are very welcome. I am happy to be able to help and contribute back to a super bunch of very talented guys. Jeff...
#10
How to connect start buton with LPT port and what is comand in G code Please send me full information how to connecting and setup and programing Thanks Last edited by bpetkov; 09-17-2010 at 03:22 PM. |
#11
I also need tohave "Start Cycle " push button with cable to controler.How to conect betwen witch pin for exampel 14 is free and ground .and what i to write in G code. Do you have full info about this Thanks |
#12
| Bpetkov, Pin 14 is a output it will not control the cyclestart, that requires a input pin Jeff...
| Start macro with input button | geahr | Mach Software (ArtSoft software) | 4 | 09-17-2009 09:52 AM |
| Need Help for Mach 3 Macro+Start by ext.Button | Morianer | Mach Software (ArtSoft software) | 1 | 07-16-2009 02:15 AM |
| Need Help!- Can spindle start when you hit the Z-axis button? | moldcore | Milltronics | 2 | 04-26-2009 08:14 AM |
| Interact 412 - CYCLE BUTTON RESTART SPINDLE | Zhales | Bridgeport and Hardinge Mills | 1 | 07-20-2007 07:46 AM |
| Cycle Start button | kaleem1 | Mach Software (ArtSoft software) | 7 | 12-24-2005 02:05 PM |
