Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Mach Mill
Old 10-26-2009, 05:26 AM
normunds_a is on a distinguished road
Z axi problem with step changing
I have problem with Z axi “flowing”. When I engraver relief (feed rate 600 mm/min, acceleration 60 mm/min) some lines fall in. The high is not changing but some lines on material is too deep.
Using Mach 3.042.029.
Need Help!- Mach 3 step problem nenetwork Mach Software (ArtSoft software) 2 05-28-2009 12:12 PM
Spiral problem after changing inserts in lathe. chibbert General Metalwork Discussion 3 11-18-2008 01:20 PM
Need Help!- Hitachi Seiki NF 20 FANUC 6T - problem with tool changing Xavier M Fanuc 3 08-17-2008 03:55 AM
changing computers problem, frogger Haas Mills 3 03-05-2008 11:55 PM
Sharp 2412 tool changing problem longcut CNC Machining Centers 1 09-15-2007 05:02 AM
