Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Mach Mill
Old 10-19-2009, 11:53 PM
jhowelb is an unknown quantity at this point
X/A axis slaving issues
I'm having X/A axis slaving issues while setting up Mach 3 for my router.
I set A slaved to X in "slave" menu and a to "linear" and "slave to home with main" as well as active and the ports and pins. Also the motor tuning is set same as X but there is no activity on any DRO either on run progran screen or on Diagnostics.
I don't want to make any wiring connections till the software is ironed out.
What am I missing? Any suggestions?
Old 10-20-2009, 10:28 AM
ger21's Avatar
Is the A axis enabled in Ports and Pins, Motor Outputs?
When you say any DRO, do you mean the A axis, or all the axis?
Old 10-20-2009, 11:09 AM
Got it working, altho there is still no DRO showing movement for the A axis on any screen.
Changes for A axis on motor tuning seem to have no effect whatever, I can only hope that the speed of the two motors and the pitch of the two ball screws are close enough as to not cause a problem.
Just like a trip thru the looking glass into the land of Oz.............
Old 10-20-2009, 12:39 PM
ger21's Avatar
They both need to have the exact same settings. You can't try to compensate with different settings.
And I don't think the A DRO is supposed to show anything when it's slaved.
Old 10-21-2009, 11:41 PM
Arbo is on a distinguished road
Yeah, I have x and a slaved, and A never shows anything, which is fine, because it is just X #2.
I actually used one of the screen editing programs and got rid of the A data just to clear up some screen.
G540 and slaving KTP Gecko Drives 13 03-08-2010 02:32 PM
Motor Tune and Slaving?? finishlinewrx DIY-CNC Router Table Machines 6 05-19-2009 01:31 PM
Slaving axis & other issues George Mach Mill 5 04-17-2009 03:19 AM
Slaving 2 axis together Mach3 retromulticam Mach Software (ArtSoft software) 1 04-29-2008 07:42 PM
