Results 1 to 4 of 4
Thread: beginner needing some help please :)
    Sep 2009
    Hi all,
    First off, im new to the cnc world but i am getting my feet wet quick.
    The machine i bought was used, and the control software that came with it has absolutely no support whatsoever. So i decided to set the machine up with mach 3. I have all of the stepper inputs, and screw settings correct.
    The problem i am having is actually setting the zero position of the machine. I haven't been able to figure that out yet. Any hints on how to do this. Also, the software that came with the machine had my z axis setup where positive was going towards the table, and zero was at the highest point. Is there a way to setup mach3 in that fashion.
    Registered jalessi's Avatar
    Feb 2007
    U.S.A.
    Post
    425hpChargerSRT,
    You can change the direction by changing the Dir LowActive setting for that axis.
    See attached image for more help.
    Jeff...
    Attached Thumbnails Attached Thumbnails beginner needing some help please :)-cnc-chart.jpg   beginner needing some help please :)-dir_lowactive.jpg
    Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
    Registered bill-the-cat's Avatar
    May 2009
    New to Mach
    Being new to Mach, you may want to check out these tutorials. They should answer a lot of your questions.
    http://www.machsupport.com/videos/
    Bill (the Cat) Shubert
    Sep 2009
    Quote Originally Posted by jalessi View Post
    425hpChargerSRT,
    Jeff...
    Great, thanks for the help jeff. I knew there was something i was missing.
  1. New guy needing advice!
    By ThatguyDave in forum Fadal
    Last Post: 05-21-2009, 09:36 PM
  2. New Guy Needing a Little help here
    By Shop_Smith_Popp in forum WoodWorking
    Last Post: 03-30-2009, 01:46 PM
  3. Needing help please
    By Larry Myers in forum G-Code Programing
    Last Post: 10-04-2007, 03:22 PM
  4. needing some imput
    By sodickappsguy in forum General Waterjet
    Last Post: 07-30-2007, 10:57 PM
  5. New guy needing help please...
    By studysession in forum Welding, Brazing, Soldering, Sealing
    Last Post: 01-12-2007, 02:18 PM
