Results 1 to 5 of 5
Thread: MACH 3 Motor Tuning Max Velocity 1150? No higher?
    Oct 2006
    Hello guys.
    I got the machine working fine but Rapid is very slow.
    I have P4 2.5Ghz.
    Set Mach 3 at maximum 45000Hz.
    In the Configuration page, I can crank velocity up to max at 1150.
    Obviously, lower to 25000Hz reduced the max down to about 750.
    My servo drive/motor can run up to 2500RPM.
    but currently at max setting 1150 in MACH 3, it run about 250RPM.
    run setting at 750 in Mach 3 generate about 150 RPM.
    Anyone know how to change this setting to run much faster?
    Jef
    Dec 2004
    Quote Originally Posted by cjchands View Post
    Hello guys.
    I have P4 2.5Ghz.
    Jef
    If you are jogging from the keyboard and getting slow rapids, hold the shift key down while jogging, this will overide any percentage settings which are found on the tab key flyout.
    A little more info on the drivers and such might be helpful.
    Mike
    Mar 2003
    Shelby Twp, MI....USA
    Jef
    Get a newer version of Mach3 that can run at 100Khz, or get a Smoothstepper than can run at 4Mhz. www.warp9td.com
    H.O
    H.O is offline
    Jul 2007
    Sweden
    What's the encoder resolution? 2500lines?
    Either get an external pulse engine like the Smoothstepper as Gerry sugests or look up if the servo drive has a pulse multiplier. The pulsemultiplier will let you get the speed up but the minimum step size (or resolution) goes down with it.
    If you need BOTH high resolution and high speed then getting an external pulse-engine is the only way to go.
    /Henrik.
    May 2008
    My 0.02
    I had a smoothstepper (and still do, for that matter) but went back to parallel cables due to some unresolved bugginess. I know a lot of folks use the smoothstepper successfully, but it didn't seem so great for my application. Do lots of searches on the various forums, including Mach and Warp9.
    1. Need Help!- Mach 2 motor tuning
      By vicsrc in forum Mach Mill
      Last Post: 05-19-2009, 09:06 PM
    2. Need Help!- Need help with motor tuning mach 3 REX RHT34-640 Gecko 201 drive with camtronics box
      By MAKESOMECHIPS in forum General CNC (Mill and Lathe) Control Software (NC)
      Last Post: 04-07-2009, 01:19 PM
    3. Replies: 3
      Last Post: 03-18-2009, 10:38 AM
    4. Need Help!- Mach 3 motor tuning
      By nenetwork in forum Mach Software (ArtSoft software)
      Last Post: 03-03-2009, 02:43 PM
    5. Help needed for mach 3 motor tuning
      By Grandad in forum DIY CNC Router Table Machines
      Last Post: 04-25-2006, 06:54 PM
