Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Mach Mill
Old 10-05-2009, 09:24 AM
sconklin is on a distinguished road
Pullin my hair out now! Z not working or missing steps
I have an early version of a sidewinder cnc w/ mach 3
I just re set it up and am having one prob after another. My current problem is this. I went to run a simple 2.75 ring program( ran it at least 4 times the day before) after getting the machine going yesterday. The router is supposed to cut through 1/4" material and only cuts maybe a few thousanths before moving to the next outer circle.Mach 3 shows the correct depth per pass but the machine is not doing what mach thinks it is. I can see the z stepper motor trying to turn w no results. When I hit the stop button and move it up and down manually w/ the page up and down button it works fine.Can anyone help, hopefully its a simple fix, This machine is gonna put me in an early grave.
Old 10-05-2009, 10:12 AM
ger21's Avatar
Try lowering the acceleration.
Old 10-05-2009, 10:33 AM
Hi Ger
Thanks for the response. The g code written in cut 2d only calls for 1"/minute(very slow) or are you saying to alter it elsewhere?
Old 10-05-2009, 10:55 AM
I went under motor tuning reset the steps per inch to 2000 from 8000? , the velocity reads 60 ,accel was 6 and I reset to 3.
I shut it down ,re started Mach 3 w/ the new settings and the Z screw only turns a tiny but on the plunges? Didnt help.
Old 10-05-2009, 03:20 PM
Anybody have any ideas w/respect to settings? I am dead in the water. It was not doing this the day before. It just started out of the blue and I havnt touched the Z axis?
Old 10-05-2009, 03:31 PM
Starleper1 is on a distinguished road
Are you by chance using the Gecko G540?
Old 10-05-2009, 04:00 PM
No, I dont believe so. This is a 1 1/2 year old sidewinder cnc.
Old 10-06-2009, 08:42 AM
I had the same issue with my setup but i have the G540. I found a thread of an explainable reason that the G540 needs the "sherline mode" checked under general config. It opens the pulse width up to 40micro seconds. Maybe give that a try and see what happens.
Missing steps when jogging in more than one axis vonnieda Benchtop Machines 31 08-05-2009 12:23 PM
Need Help!- Missing steps? beezerlm Machines running Mach Software 4 05-12-2008 09:59 PM
Servos jumpy n missing steps.... bigal Gecko Drives 8 09-29-2006 03:52 PM
Missing steps ? DavyD Machines running Mach Software 9 05-10-2006 02:06 AM
Missing Steps with Laptop alanc2 TurboCNC 6 08-08-2004 02:39 PM
