Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Mach Mill
Old 10-03-2009, 11:51 AM
sconklin is on a distinguished road
Help! Mach 3 running wild
I just swithed my computer over from a smaller machine w/ a single motor on the Y axis to another machine that has two motors 1 plus a slave drive. After upgrading the lead screws on the machine (which was made w/ extremely undersized lead screws) I went to run a test program w/a 2" circle. The machine is trying to make a circle that is 10" in diameter. Mach 3 is showing the correct g code but the machine seemes to be interpreting things to be much larger than they are supposed to be. Could it be the settings whiich I got right off of the Sidewinder website??
If anyone has experienced this I would greatly appreciate your input.
Thanks in advance
S
Old 10-03-2009, 12:02 PM
Jay C is on a distinguished road
Simple, you need to turn your motors to match the steps per inch. Sounds like a starting point is to divide the current setting by 5 (10 vs 2 = 5x too much). Use and indicator to test your values before trying to cut anything.
Old 10-03-2009, 03:27 PM
Thanks Jay C
I had someone helping me and I was reading numbers off of my laptop as she was inputing in Mach 3. I noticed she had the x and y set at 8000 ipm instead of 3200.
Wow.
It seams to be working as well as it can.
Thanks again
Problem- Jogging fast running slow MACH 3 555e CNC Plasma and Waterjet Machines 1 08-30-2009 05:42 PM
Mach running a cnc cutoff saw cut more Machines running Mach Software 0 11-06-2007 12:21 PM
Running BobCad/Cam and Mach 3 on the same machine? Corvus corax BobCad-Cam 9 01-11-2007 09:19 PM
Boss 6.1 now running on mach 3 creep_pea Bridgeport and Hardinge Mills 13 08-15-2006 07:43 AM
Anyone running Mach\Gecko's in a commercial shop? jsatter Mach Software (ArtSoft software) 6 06-28-2006 09:55 AM
