Results 1 to 8 of 8
Thread: CUTLIST
    Oct 2007
    CUTLIST
    Hi, I'm looking for a wizard where I could lay a full sheet of plywood and cut different pieces of different size in it and enter the kerfs of the router bit and be able to consider the grain of the wood while cutting and have the possibility to use tabs to hold the cut pieces together.
    Is there existing wizards to do that kind of work?
    Thank you
    Mar 2003
    Shelby Twp, MI....USA
    No. If you're talking about square or rectangular parts, you want optimization software. There are some inexpensive ones, but anything that will output g-code will probably be rather expensive.
    Oct 2007
    Thank you for the reply, I have a few files that where made for Therwood and usable with Shopbot, can I use these with Mach3.
    About optimization software that pruduce G-Codes do you have any recommedation
    Moderator Switcher's Avatar
    Apr 2005
    mydxf.blogspot.com
    Vcarve Pro, will do what you want (It's not a Mach3 wizard)
    http://www.vectric.com/WebSite/Vectr...w_overview.htm
    Free DXF Files - myDXF.blogspot.com
    Oct 2007
    Hi, anything cheaper that could do the same job, I'm only starting with this CNC stuff and it's only a hobby for now.
    Thank you
    Apr 2005
    mydxf.blogspot.com
    Quote Originally Posted by BOBINETTE View Post
    Thank you
    Not that I know of.
    Oct 2007
    A stupid question, about the Thermwood files, can I process them with Mach3
    Thank you
    Mar 2003
    Quote Originally Posted by Switcher View Post
    Optimization and nesting are not exactly the same thing, and since V-Carve Pro does Nesting, I didn't think it could do it. It doesn't actually have any settings to determine grain direction. However, as long as all your parts are drawn so that te grain is running the same direction, V-Carve Pro will give you the option to NOT rotate them, keeping the grain aligned.
    I don't know if you'll find anything cheaper that'll output g-code to Mach3.
    Here's a beta that will export a nested .dxf that you can use in any CAM program. http://www.cabinetpartspro.com/Part%20Nester%20Pro.htm
    As for the Thermwood files, I'll guess no, but load them into Mach3 and see if you get an error.
    1. Cutlist for Sketchup!!!
      By blackbeard52 in forum WoodWorking
      Last Post: 09-05-2008, 07:03 AM
