Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Mach Mill
Old 08-25-2009, 09:22 AM
scotty001 is on a distinguished road
stepper as spindle motor help
Hi guys is it posbile to run a steppermotor as a spindle motor in mach3
as sherline are supplying there mills with a choice of dc motor or stepper
as a spindle
i am trying the stepper option out but cant get it to work ports and pins are fine i know that for sure i run the program and the stepper will not tern at all
are am i going about this all wrong ??
Old 08-25-2009, 09:28 AM
LeeWay's Avatar
LeeWay is on a distinguished road
Are you running it as a spindle? You would need to set it up that way to get the gcode to activate it and to regulate the speeds.
Lee
Old 08-25-2009, 09:56 AM
would like to but i am getting no response from the motor
and i am sure its connected fine
the gcode dont seem to activate it
using
S500 (SPEED)
M3 (START MOTOR)
M5 (TO STOP MOTOR)
Old 08-25-2009, 10:33 AM
LeeWay's Avatar
This pdf may help you. Toward the end it has pictures of the mach screens that you need to deal with in order for Mach to control a spindle. Any spindle.
Start at about page 12.
http://www.homanndesigns.com/DigiSpeed_SD_User010.pdf
Lee
ger21's Avatar
Need to see your ports and pins settings, as well as the spindle page of ports and pins.
Old 08-25-2009, 10:54 AM
got no real way to show you my ports n pins
but i know they are correct becouse if i asign them to x or y axis it works perfect. as for spindle settings page it is stock settings not real sure what needs changing here
Old 08-25-2009, 12:43 PM
ger21's Avatar
print screen key, then paste into MS Paint.
Old 08-26-2009, 01:45 PM
heres my ports n pins
if i disable the spindle and enable A-axis with the same pin settings
it works fine which leads me to think these settings are correct
Old 08-26-2009, 02:13 PM
LeeWay's Avatar
I think you need to enable spindle relays above. Not sure, but I think so.
You also will need to setup the pulley ratio even though you don't have one. It will give you minimum speeds. That is at the bottom toward where you setup safe Z.
Then in the motor tuning, you need to enable the spindle and start playing with the step and direction variables. I think this will get you somewhere.
Does an output have to be enabled as well? Maybe. You might try that too.
Lee
Old 08-27-2009, 02:51 AM
Unhappy
tryed this but still no luck guys
  #11   Ban this user!
Old 08-27-2009, 04:47 AM
LeeWay's Avatar
What do you have your velocity and acceleration set at?
Lee
  #12   Ban this user!
Old 08-27-2009, 05:10 AM
jalessi's Avatar
jalessi is on a distinguished road
Post
Scotty001,
What about assigning the pins for the outputs?
See the attached image.
Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
Lathe Variable Spindle motor options? VFD? Servo? Stepper? DC? whiteriver General Electronics Discussion 21 03-16-2011 07:38 PM
Spindle and Stepper Motor Oscillation. Is it a Problem pzzamakr1980 Tormach PCNC 15 02-27-2010 07:57 PM
Spindle motor stopped, stepper motors flaky... americanbehn Machine Problems, Solutions , Wireless DNC, serial port 1 11-05-2007 08:25 PM
Beltdrive-stepper motor-stepper motor driver Georg Stepper Motors and Drives 0 10-16-2007 04:56 PM
Opinions Please: Stepper as a spindle motor Max Power Stepper Motors and Drives 5 11-03-2006 07:28 PM
