Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Mach Mill
Old 08-20-2009, 09:19 AM
Morianer is on a distinguished road
Problems with actual version of Mach 3
Hello
Hope there s someone who can help me.
I use Mach 3 Version 1.84 with normal Steppers without any Problems.
Because the Kernel Speed is only at 45 khz i downloaded the New Version 2.0 of Mach 3......
And now the Problem:the Axis don t run soft at all if we can call it run.Is there something i forgot????
How can i use encoder feedback that the software stops if position is not correct ???Is there a macro for it or how could i say how many steps/positions the encoder is like(for example 500 or 1000 steps per rev.)
Old 08-20-2009, 10:12 AM
ger21's Avatar
http://rogersmachine.net/encoderinterface.html
Not sure about you're problem, though.
Old 10-17-2009, 03:54 PM
Tiziano Deodato is on a distinguished road
I had a similar problems with the motor when moving from mach3 version 1,8 to the 2.63 one.
In "General Config" menu, try to set the field "shuttle acc." to 0.01.
Mach3 can read the encoder but do not perform any control.
I know is you can perform a check by using a macro with "Brain" or "Macro pump" and stop in case of error.
Goes to
http://www.machsupport.com/forum/index.php
and search for Brians and/or Macropump
Regards
Upgrading to the latest Mach version watsonstudios Mach Software (ArtSoft software) 4 06-19-2009 08:04 AM
Settup problems wih Mach 3.... Green0 Syil Products 7 04-12-2009 02:50 AM
Need Help!- Mach & cnc router interface problems BlkNotes DIY-CNC Router Table Machines 1 04-10-2008 05:22 PM
Mach Lite Version? Regnar Mach Software (ArtSoft software) 1 02-15-2008 08:28 PM
Problems with demo of Mach tt_raptor_90 Mach Software (ArtSoft software) 5 05-24-2006 10:31 AM
