Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Mach Mill
Old 08-17-2009, 01:33 AM
chessmen is on a distinguished road
Mach3 and Probotix
Hello one and all, I am very new to CNC Router, I am 68 years old and live in Canada.Does any one have all the Mach3 setting for Probotix Fireball V90 ?.
I appreciate any help I can get.
Regards chessmen.
Old 08-17-2009, 02:31 AM
jalessi's Avatar
jalessi is on a distinguished road
Post
Take a look at the attached images.
ID:	86775   Click image for larger version
ID:	86776   Click image for larger version
Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
Old 02-15-2011, 11:47 AM
busby is on a distinguished road
Looking for Mach3 settings for V90 acceleration and more.
Regards chessmen.
Did you ever get the Mach3 settings from anyone on the forum? If so, or if you've come up with good working settings by now, would you be into sharing the settings file? I'm having some difficulty with missed steps in my x axis direction and feel it may be something to do with settings, perhaps in the acceleration or similar area.
Cheers
Donn
Old 02-21-2011, 07:15 AM
kmacht is on a distinguished road
I don't have a fireballl v90 but am running the probotix bi-polar drivers on my JGRO. I was having all sorts of trouble getting accurate cuts with it. What finally worked was turning on 1/8 microstep. I don't know why but when I used full step my parts were always .010 to .020 off. Turning on 1/8 microstep and they are now coming out perfect.
Keith
Old 02-21-2011, 10:35 AM
Full Step vs 1/8 microstep
Keith
Thank you Keith, I'll look at this today. I don't believe my setup is full step, but it is possible. The behaviour is sporadic, seems to be worse the more I need it to work :-) I'll post back after I try. If switching gives me better performance I'll also let them know at Probotix.
Cheers,
Donn
Old 03-06-2011, 04:28 AM
alecdamonki is on a distinguished road
Exclamation problems with V90
hi,
Have set up and wired 3 axis V90 according to 4-Axis_ProboStep_wiring_diagram.pdf minus 4th motor and limits and am having dramas getting a connection to windows 7 with mach3 i've included pics of mach3 config and have followed directions to the letter motors hum but don't jog lpt1 is 0x378 pleez help...
Name:	mach3port settings.jpg‎
ID:	128205   Click image for larger version
Old 03-06-2011, 04:48 AM
problems with v90
hi just adding wiring pic
Old 03-06-2011, 06:02 AM
ger21's Avatar
In Ports and Pins, your motors step and direction are set to port 0. They need to be set to port 1.
Old 03-06-2011, 06:03 AM
ger21's Avatar
Enable pins also should be set to port 1
Old 03-07-2011, 01:05 AM
will let ya know if that is my only problem... :S
  #11   Ban this user!
Old 03-08-2011, 12:30 AM
drivertest.exe
Hi, have run drivertest without mach3 running and pbx-rf driver board turned on with usb and parallel port plugged into computer and it returns "No driver sensed installed run drivertest" Do I need a software driver so the computer recognizes pbx-rf? uploading a wiring pic of driver board also All help appreciated...
Alec
Old 03-08-2011, 04:08 PM
ger21's Avatar
Drivertest is for the Mach3 driver. If it's not working, then ach3 won't work. Can you post a screen shot of the Mach3 Diagnostics page?
Also, when you installed Mach3, did you reboot when you were instructed to? If not, you may need to completely uninstall it and reinstall. Read the installation part of the manual carefully, and watch the installation and setup video at www.machsupport.com
Probotix bigtonyicu Stepper Motors and Drives 21 05-28-2012 07:39 PM
Need Help!- E-Stop, Probotix PBX-RF, and Mach3 jeffmorris DIY-CNC Router Table Machines 18 11-21-2010 11:40 AM
Is this Probotix kit ok? slashmaster Benchtop Machines 13 06-27-2009 09:15 PM
Newbie- Probotix / mach3 Connection problems oldskimmer DIY-CNC Router Table Machines 3 04-15-2009 05:35 PM
ProBotix marinCNC Want To Buy...Need help! 4 09-12-2008 07:02 AM
