i got some answers from my last post, but still have more questions... (sorry...) lets say I only have 1 axis for siplicity sake (X axis we'll say) and it's hooked up to pins 2 for both direction and steps, also pin 10 for data input so mach knows how many steps have been taken in actuality. lets say the're 32 steps pr revolution, and 1 rev = 1 mm (unit) and here is the motor tuneing: 32steps 3000velocity 21 accel 5us steppulse 2dir pulse ok, here are the actual questions : 1) to move the motor 'forward' one revolution: output: 5usec (on) ??usec (off) looped 32 times. (on pin2) correct? wrong? kinda? 2) to move the motor backwards would it: output once(on) for 2usec then continue like the forward pulses? or would it do 2usec(on), ??usec(off) looped till amount of steps desired. first one right? second one right? none of them right? 3) data being sent to mach, is it: a) when pin10 is on it counts one pulse till it's off. b) distinguish direction between 5 usec to move cw, and a 2usec pule = ccw? c) something else? p.s. question #2 was sorta answerd in a previus post, but reading the manual i 'think' the answer i got from the thread and the manual contradict each other... so i just want confirmination... cheers! Nick_B |
| 1: unfortunate, but at least that way i can see if it missed steps (or added them) 2: yes, the distance between pulses i assumed to be variable depending on the speed. but also, yes i agree it is probably more complex then i think, hence why I'm trying to figure it out btw, now I'm starting to think mach assumes the motor controller fills up missed steps in case drilling into the object being molded slows down the accel rate? 3:there is no way to control the servo in both directions on one pin? (there for making it impossible to a 5 or 6 axis with one port?) 4: unfortunate, but ok ![]() Edit: can mach 3 use pins 1, 14, 16, 17 ? thanks for all your help so far if you could explain it in total a bit better that would be much appreciated XD i keep designing circuits and then figuring out i need to change them because of limitations of mach.... (and I want to get it right before i start building)thanks again XD Last edited by Nick_Black; 08-08-2009 at 10:13 PM. |
yes, in essence ![]() btw, i think you missed my edit (but kinda answerd it also..) can mach 3 use pins 1, 14, 16, 17 ? (since you said 12 output pins, i assume that is a yes) and thank you sooooo much for putting up with me XD |
| I believe so, but I'm not positive.
| Does Freemill output to Mach 3? | teamtexas | General CAM Discussion | 5 | 09-25-2009 06:33 AM |
| Will Mach Output Quadrature ? | epineh | Mach Software (ArtSoft software) | 0 | 03-10-2008 05:17 AM |
| Does Mach support Phase output? | Jcadwell | Mach Mill | 1 | 01-30-2007 05:39 PM |
| 0-10V output control with Mach 3? | fatal-exception | Mach Mill | 3 | 01-11-2007 12:39 PM |
| catia NC output with mach 2 cnc? | hpghost | General CNC (Mill and Lathe) Control Software (NC) | 5 | 09-02-2006 12:22 AM |
