Hi all, I have generated a toolpath from Meshcam and I have also generated a toolpath in Flashcut CNC (demo). Both of these look great in Flashcut (demo) but when I drop the g-code into Mach3 which I am using to run my machine, there are parts of the toolpath missing. It just seems that there is a setting that I am missing or something? I don't have the g-code with me to post right now but any ideas or guidance would be GREATLY APPRECIATED.. Thanks in advance, Jarrod |
| You're in demo mode and it's only showing 500 lines of g-code.
| I thought about that after I posted. I forgot to drop the license file into the Mach3 folder. One thing though....What it does do on one file is this: The file is roughly oval shaped. It makes it about 3/4 of the way around and then I'm sure I'm reaching 500 lines. However, instead of simply stopping (or completing the oval like I would like), it makes a straight line right back to the starting point. Should it do that? Again, I know that most if not all of my problem is that I forgot to drop the license file in. Thanks, Jarrod |
| DFX is not imported correctly... | ihkim | GRZ Software- MeshCAM | 11 | 01-07-2010 11:57 AM |
| Need Help!- .stl file used for toolpath verification takes too long to load? | Peoria | Mastercam | 3 | 04-01-2009 06:34 PM |
| On Startup Load Mach3 | RMT | Machines running Mach Software | 5 | 07-26-2007 05:16 PM |
| Load Mach3 point clouds into AutoCAD | ger21 | Autodesk Software (Autocad, Inventor etc) | 0 | 03-04-2007 02:31 PM |
| MASTERCAM 9.1 TOOLPATH GENERATION for Mach3 | chris59 | Mach Software (ArtSoft software) | 6 | 11-18-2006 10:58 AM |
