Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Mach Mill
Old 08-05-2009, 06:22 AM
cjchands is on a distinguished road
** Please help - MACH 3 not sending out any signal for different PC **
hi.
I am trying to find the post for this question, but unable to do so.
I set up a PC (P4, 1.8 Ghz) and ran MACH 3 on 3 axis mini mill with no problem.
However, when I changed to "LABTOP", it DOES NOT send out any signal nor the diagnosis page doesn't see any INPUT incoming.
I heard that Laptop doesn't provide enough AMP?
Or could be other factors that I am not awared of....
everything else send up the same way as PC.
Parallel ports work.
Thank you in advanced.
Jeff
Old 08-05-2009, 08:47 AM
James L is on a distinguished road
Laptop
What model is your laptop and what software is running on it? Does it have a wireless network adapter built in?
Old 08-05-2009, 11:08 AM
Mongkol is on a distinguished road
Smile Laptop not support for mach3
Jeff,
Pls have a look on software requirements at http://www.machsupport.com/
Mach3 Minimum Requirements:
Windows 2000/XP Operating System
1Ghz CPU
512MB RAM
Non-integrated Video Card with 32MB RAM
Basic Computer Skills (ability to copy/rename files, browse directories, etc)
Desktop PC if using the Mach3 Driver (Laptops are not supported because the power saving features of the chipsets disrupt the pulse stream)
Hope this help
Mongkol
Old 08-05-2009, 10:23 PM
Laptop has no wireless built in, just old model type with built in PC parallel port.
US WINDOW XP
So it doesn't due to the fact it send out enough current to the drive, but rather pulse signal got interupted?
I saw some pictures where people did use Laptop to control CNC...so musta been some way to do it.
Either way, thanks for confirmation.....will just have to do with PC for now
Sending Programs From Memory Moparmatty Haas Mills 3 03-25-2008 09:01 AM
Sending Program ... politecnica Fanuc 0 03-05-2008 06:28 AM
Sending programs to fadals Delw Fadal 10 05-30-2007 06:41 PM
Trouble sending and recieving Jedi Fanuc 1 05-21-2006 07:42 AM
Sending the table to the zero coordinates? saturnnights Mach Mill 6 02-28-2006 11:07 AM
