Results 1 to 4 of 4
Thread: where is the home switch?
    Jan 2009
    I know that the limit switches are located on each end (or travel) of each axis but where do I put my home switch???? anyone pls explain.
    Registered LeeWay's Avatar
    Jun 2004
    Not real familiar with it, but most use one of the limits as a home switch. Home can be anywhere in the cutting area though. On a mill, home might be dead center and on a router, the home might be at one limit switch. It all depends on what you want to reference off of. Where you want to start cutting from.
    Lee
    Registered Bubba's Avatar
    Mar 2004
    LaGrange, GA USA
    I use limit switches as home also, but if your going to have separate ones, I would put it close to one of the limit switches. You have to tell your controller which direction home is located and if the switch is in the middle, the controller might not know which direction to travel! You can always set that location to any desired point. So lets say you have a total of 12" travel and you want the 0" location in the middle and the home switch is at the left hand extreme. You home in the negative direction. When it gets there, you tell it that is -6" and your done.
    Art
    Jan 2009
    Thanks for all the replies guys. I'm just going to install the limit switches for each axis and use each one of them as home but don't know exactly how to configure that in mach3.
  1. Is it possible to use the home switch as the limit switch as well?
    By Darc in forum Mach Software (ArtSoft software)
    Last Post: 11-02-2012, 01:25 PM
  2. limit switch- home switch
    By normd in forum CamSoft Products
    Last Post: 05-16-2008, 07:56 PM
  3. limit switch and home switch setup
    By Runner4404spd in forum General Electronics Discussion
    Last Post: 12-15-2005, 08:58 AM
  4. Limit Switch / Home Switch in Software
    By Sanghera in forum General Electronics Discussion
    Last Post: 11-01-2004, 06:58 PM
