Results 1 to 5 of 5
Thread: mach3 Y axis 2 stepper 2 ballscrews setup
    Jan 2009
    how to setup mach3 mill running Y axis with 2 stepper motor + 2 ballscrews?
    Mar 2003
    Shelby Twp, MI....USA
    Set up the second as A, B, or C axis. Make sure all settings are the same (except pins). Go to Config > Slaving and assign the slaved axis to Y.
    Jan 2009
    Thanks ger21!
    just curious how did those people do it with 6th axis using 2 ballscrews n 2 motors on Y axis ? parallel port only have 12 outputs
    Mar 2003
    You can use two ports.
    Apr 2011
    Brunei
    I got d same problem and my second motor still not working though already Config > Slaving and assign the slaved axis to Y. Anybody knows how to set d others with relevant of slaving d same axis.
    4 ur info I'm using 4 axis TB6560 driver board.
    1. Z-axis setup/control in Mach3
      By Richotech in forum Machines running Mach Software
      Last Post: 08-10-2012, 12:49 PM
    2. Need Help!- Mach3 A axis (4th axis) setup?
      By cadcamslawek in forum Mach Software (ArtSoft software)
      Last Post: 01-17-2012, 09:23 PM
    3. Mach3 R3.00 Mill 4 axis Foam cutter setup
      By Andy Smith in forum Mach Mill
      Last Post: 01-25-2008, 08:19 AM
    4. Featurecam Lathe Setup X axis MAch3
      By whiteriver in forum FeatureCAM CAD/CAM
      Last Post: 02-20-2006, 06:04 PM
