Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Mach Mill
Old 07-26-2009, 02:23 PM
Frogblender is on a distinguished road
How to zero machine coordinates???
Howdy... I wish to zero Mach3's machine coordinates.
I have Mach3->Config->Homing/Limits->Auto Zero turned OFF, for good reason (shown below).
If it is turned ON, then the machine coordinates get set to zero whenever the machine is zeroed. But how do I zero the machine coordinates if it is OFF??
Currently, when starting Mach3.exe, it makes a stupid assumption: "mach3.exe is starting, therefore mill must be at 0,0,0" - even if it is not. Which will eventually cause a toolcrash.
Reason for leaving AutoZero OFF: this allows you to check for missed steps: Manually zero the mill, run a job, then re-zero the mill: if the DRO's still read close to zero, then no steps were missed.
Old 07-26-2009, 02:42 PM
ger21's Avatar
They shouldn't.
When you home (ref) the machine, you're zeroing Machine Coordinates, IF you have Auto Zero checked.
How are you zeroing the machine? The zero buttons here zero the G54 coordinates (or whatever other you might be in), but don't change the Machine coordinates, whether Auto Zero is checked or not.
Turn on Persistent DRO's in General Config.
Could you explain this a little better? I don't quite understand what you're doing. And btw, Mach3 has a Verify function to check for lost steps. On the MDI page.
Anyway, I'm pretty sure that the only way to zero Machine coordinates is to Home/Ref the machine.
Old 07-26-2009, 06:11 PM
benjamint76 is on a distinguished road
to rezero the machine:
under DRO you see machine coord, click thatbox turns red move your spindle to home and then start clicking ZERO.
Once that is done click machine coord again and you will be back in part mode.
Easy enough?
Old 08-04-2009, 11:37 AM
Easy enough?
Doesn't work. When machine coord button is red, clicking ZeroX,Y,Z as you suggest does NOT change the values to zero - they remain unchanged.
Old 08-04-2009, 12:36 PM
ger21's Avatar
Did you read my post?
zero machine coordinates stoneyreef Mach Software (ArtSoft software) 1 05-08-2009 02:50 AM
Workpiece coordinates jeffm General CNC (Mill and Lathe) Control Software (NC) 2 11-10-2008 06:43 PM
G92 coordinates monaro mike Fanuc 12 07-28-2008 07:27 AM
G31 uses machine coordinates? kerryveenstra Tormach PCNC 1 04-27-2007 01:45 AM
FanucOM machine coordinates bcdnm Fanuc 5 11-22-2006 05:29 AM
