Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Mach Mill
Old 06-24-2009, 06:36 PM
Crawler374 is on a distinguished road
Trouble converting files.
Hey all, I'm really new to this, so bare with me. I have my files in Cambam, but I have no clue how to set up mach to cut out my drawing. anyone help me here? is there a step by step process I can't find? thanks everyone.
Old 06-24-2009, 06:53 PM
ger21's Avatar
Export g-code from CamBam. Load into Mach3. Zero X, Y and Z axis in relation to part. Press Cycle Start.
Sorry to be vague, but try to ask more specific questions. I'd rather answer 1000 questions then write a book.
Old 06-24-2009, 10:00 PM
My question is specific, I absolutely have NO CLUE how to transfer it over, nor use mach.
Old 06-25-2009, 06:00 AM
ger21's Avatar
You first need to learn how to get g-code from CamBam. I've never used it, so can't help there.
Old 06-25-2009, 07:44 AM
Oh okay, Thanks for your help. Anyone else?
Old 07-03-2009, 11:50 AM
tigran is on a distinguished road
Why don't you use Lazy Cam? It is automatically posting GCode to mach 3 and it is simple in use.
I've never heard CamBam, but theoretically there must be the way, to save Gcode in .txt file, or just copy it from CAMBAM, and then go to Mach3, there in Program Run Menu you'll see a button EDIT GCODE, press it, then the empty txt document will open, you can PASTE the GCODE there, save this document, then in the same menu press another button LOAD GCODE, there choose .txt file format and open the saved document! Thats all... You can repeat this last step, if you've saved the GCODE from CAMBAM directly in .txt format!
Need Help!- CONVERTING DWG FILES CNC_BOB Mastercam 8 11-12-2008 05:52 PM
Converting Illustrator files to Gcode files acoop101 General Metal Working Machines 1 06-05-2008 03:53 PM
converting *.nc to *.ncp files davidsutton General CNC (Mill and Lathe) Control Software (NC) 0 10-04-2007 09:38 AM
Trouble cutting after converting from .eps to .dxf file Carl26 Laser Engraving & Cutting Machines 16 08-02-2007 09:15 AM
converting MC files to DXF Sprew Mastercam 1 11-04-2006 11:18 AM
