Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Mach Mill
Old 06-20-2009, 08:29 AM
Starleper1 is on a distinguished road
Problem with tuning motors
I am setting up my machine using Mach (obviously) Whats happening is that when i calculate the steps per, it gets me close. Then i use the steps per function on the setup page, where it asked you how far to move and then how far it actually moved. It adjust to the proper steps per. It then moves the distance it says. Now, when i jog in step mode, set at say .100, it will only move like .088-.090. Backlash isn't an issue either. Anyone run into this at all?
Old 07-03-2009, 12:08 PM
tigran is on a distinguished road
If the machine moves to 88-90 at your command 100, it means your'e close to the right value of steps per. Try to change steps per value and measure the real move...
In mach3 help.pdf there's a formula, that connects the step of your motor with the step of the the moving spiral... try to read there...
Tuning the motors lamicron Plasma, EDM and other similar machine Project Log 1 02-07-2009 10:54 AM
Need Help!- Cannot get the motors to jog in the motor tuning... Rob27 Mach Software (ArtSoft software) 24 12-29-2008 04:23 PM
tuning motors cob Mach Mill 6 05-13-2008 02:07 AM
tuning motors mach3 cajuil Machines running Mach Software 1 03-25-2008 04:21 PM
Tuning motors in Mach3 tybrenis Mach Software (ArtSoft software) 4 05-07-2007 01:59 PM
