Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Mach Mill
Old 06-15-2009, 03:49 PM
jasper371 is on a distinguished road
Exclamation Mach3 not moving motors
I'm new here, and hopefully this is the right place for my problem.
I'm using Mach3 on a IBM Thinkpad 600e, running windows XP. I have the printer cable hooked up to the computer, coming from the box that has the X, Y, and Z cables that go to the mill. I am using an older Sherline mill.
Now, the problem. I am using the SherlineMill.xml file as the profile. When I try to Jog, the motors make a whining noise, but they dont move. Occasionally the motor may turn 1 mill, but it's very infrequent. I have tried using the Motor Tuning menu in the config, but changing the Velocity, Accel, and Steps Per doesn't seem to have any effect.
Any help would be GREATLY appreciated. I'm pretty new to using the Mill and CNC'ing in general.
Old 06-15-2009, 04:28 PM
ger21's Avatar
Do you have it in "Sherline Mode"?
Old 06-15-2009, 04:32 PM
Yes, it is in the Sherline 1/2 mode. I think it is most likely a problem with how much voltage is being sent to the motors, but I'm not sure how to fix it.
Edit: Here's some pictures of the controller. Hopefully these will help. The bottom of the board says "Backtrack 3 axis controller revision D".
Another problem I'm having is that the X and Y axis controls in Mach3 are both controlling the same motor.
Trade offs between Moving Gantry and Moving Table gregmary DIY-CNC Router Table Machines 11 04-22-2011 01:48 PM
Problem- Mach3 y axis dc servo jumps when moving small increments only. mif73 Mach Software (ArtSoft software) 5 09-15-2008 03:32 AM
Motors not moving lamicron Mach Mill 14 05-19-2008 07:54 PM
tuning motors mach3 cajuil Machines running Mach Software 1 03-25-2008 04:21 PM
Moving Table vs Moving Gantry; Dremel vs Router chuckknigh DIY-CNC Router Table Machines 32 03-27-2007 08:48 PM
