Results 1 to 4 of 4
Thread: Where is X Y Home at 0,0?
    cag
    cag is offline
    Apr 2007
    Japan
    Where is the X and Y home?
    I am using Taig Mill with Mach3 CNC software. X Y axis cross slid table.
    Looking down with spindle as reference and standing at front of machine. The cross slides should be move in the X and Y direction. Where should the cross slides be at home executing g-code.
    Plan-A
    Facing the front of the mill, when I reference machine home and set X,Y at 0,0 the X cross table should be at the far right and the Y table should slide forward to the front. With Plan-A the g-code image is kind of upside down in the Y direction. The material has to move in positive Y, Which make spindle seem to move in –Y direction. Material moves in –X direction which make spindle seem to move in Positive X. +X-Y
    or
    Plan-B
    Facing the front of the mill, when I reference machine home and set X,Y at 0,0 the X cross table should be at the far right and the Y table should slide back or away to the back. With Plan-B the material has to move in negative Y direction, Which make spindle seem to move in positive Y direction. Material moves in –X direction which make spindle seem to move in Positive X. +X+Y
    I guess it could use all 4 location( +X+Y, -X+Y, +X-Y, -X-Y) but what is typical.
    I have included images of Plan-A and Plan-B. Not sure if I explained my question clearly.
    Plan-A
    http://picasaweb.google.com/lh/photo...eat=directlink
    Plan-B
    cag
    cag is offline
    Apr 2007
    Japan
    images
    Sorry, the images didn't make it. I included link to alternative google location. Thanks for any ideas.
    Jul 2007
    Visualize the cutter moving over the piece.
    That places your origin at the bottom left of the material. At that point the x table is to the right and the y is towards the column as in your second image.
    cag
    cag is offline
    Apr 2007
    Japan
    Thanks, I think it be a lot easer when I flip my Y.
  1. Need Help!- Anybody Home at K2?
    By SPEEDRE in forum K2CNC
    Last Post: 06-06-2008, 07:16 PM
  2. Need Help!- Home again Home again Jiggety Jig. Well Not Just Yet!
    By Mr.Chips in forum DIY CNC Router Table Machines
    Last Post: 03-18-2008, 09:58 PM
  3. home
    By frankg521 in forum Mach Mill
    Last Post: 07-18-2007, 01:13 PM
  4. Anyone Home?
    By Switcher in forum Forum Questions or Problems
    Last Post: 11-13-2006, 09:56 AM
  5. Home/G28
    By Ken_Shea in forum Haas Mills
    Last Post: 08-15-2003, 12:51 AM
