Results 1 to 3 of 3
Thread: tool comp
    Oct 2006
    england
    tool comp
    hi all,
    i have a question about some sort of tool comp in mach.
    many moon ago when i did this cnc lark for living, there was a way of cheating if sizes was not spot on. lets say i had to machine a 50mm square. i would draw it up in a program called CADLINK and do the tool path with a 10mm cutter. i would then input the G-code into the mill (cant remember the software, but it did the same job that mach does.) i would then cut the part. on measuring the part i would find out it was 50.10mm . in stead of re doing the g-code i would go into "its mach" program and say the cutter was 9.90mm. it would then take this into account and move the cutter closer to the job thus taking off an extra .05mm from all sides. the part would now be 50mm.
    hope that made sense.
    any help would be grand.
    Dec 2004
    Quote Originally Posted by blighty View Post
    hi all,
    Take a look at the manual here.
    http://www.machsupport.com/docs/Mach3Mill_1.84.pdf
    What you would do is go in and change the cutter compensation.
    I under stand that the latest release of mach3 has an updated cutter compensation, but I haven't tried it yet.
    Mike
    Mar 2003
    Shelby Twp, MI....USA
    You need to program your parts using G41/G42 cutter comp. As Mike mentioned, the latest development version of Mach3 has re written comp code, and does not work the same as the old versions. There are some rules you need to follow. Read this.
    http://www.machsupport.com/forum/ind...ic,9915.0.html
  1. Newbie- tool nose comp?
    By wronggrade in forum G-Code Programing
    Last Post: 12-02-2008, 07:46 AM
  2. Need Help!- Tool comp questioin
    By JV58 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 04-23-2008, 08:08 AM
  3. Tool radius comp
    By cijunet in forum Mastercam
    Last Post: 12-20-2007, 04:27 PM
  4. Fanuc 11m Tool Comp
    By Jfrahm in forum Fanuc
    Last Post: 07-29-2007, 06:01 PM
  5. tool nose comp.?
    By pp-TG in forum General Metalwork Discussion
    Last Post: 09-19-2006, 04:36 PM
