Results 1 to 2 of 2
Thread: circle
    Apr 2008
    circle
    When cutting a circle with Mach2 on both sides,left and right, about in the middle of the arc it looks like a straight line instead of a circle. Is that Mach2 related or it is the resolution of the stepper motors, leadscrews...?Thanks for any imput.
    Registered neilw20's Avatar
    Jun 2007
    Smile It is the machine.
    Not stepper motors, but maybe a loose coupling or belt.
    You have backlash in one or both of your axis.
    When cutting a circle each axis has to change direction during the cut.
    If there is any backlash on an axis screw, that axis stops moving while the screw/belt/rack catches up to the backlash during changes of direction, hence the straight cut.
    This can also be caused by an axis hitting the soft limit and causing a flat on one side only unless it happens to be a really big circle which could make more flats.
    Super X3. 3600rpm. Sheridan 6"x24" Lathe + more. Three ways to fix things: The right way, the other way, and maybe your way, which is possibly a faster wrong way.
  1. HELP With a 3.5" Circle cut.
    By planekrazie in forum Vectric
    Last Post: 06-01-2008, 07:02 PM
  2. Need Help!- Why is my circle not round?
    By mcjones22 in forum DIY CNC Router Table Machines
    Last Post: 04-10-2008, 09:20 PM
  3. RFQ: Circle segments
    By slick_rick in forum Employment Opportunity
    Last Post: 07-06-2007, 02:03 PM
  4. circle in G-gode
    By fred klusmann in forum G-Code Programing
    Last Post: 01-15-2007, 08:21 AM
  5. Circle problem
    By Captain Midnigh in forum Milltronics
    Last Post: 11-09-2006, 03:11 PM
