Results 1 to 4 of 4
Thread: Tool bit offset
    Apr 2008
    Tool bit offset
    When cutting a "square" with Mach2, the dimensions both X and Y are short by almost 0.200"...the line is cut inside the square. How can I program it to cut outside the square? Thanks for any imput...
    Mar 2003
    Shelby Twp, MI....USA
    Change the code to allow for the tool diameter.
    Registered Kipper's Avatar
    Jul 2006
    England
    Code:
    G0 G49 G40.1 G17
    G80 G50 G90 G98
    G21 (mm)
    (***** Cut Square *****)
    M6 T1
    M03 S20000
    M8 (Flood On)
    G00 G43 H1 Z3
    (outer Square)
    (climb mill)
    G00 X34 Y4.5 F300
    G01 Z3
    G41 P3
    G01 X29.5 Y4.5 F300
    G03 X25 Y0 R4.5
    G01 X25 Y0
    Z0
    G01 X25 Y-24.75 Z-0.6201
    G02 X24.75 Y-25 R0.25 Z-0.6299
    G01 X-24.75 Y-25 Z-1.8701
    G02 X-25 Y-24.75 R0.25 Z-1.8799
    G01 X-25 Y24.75 Z-3.1201
    G02 X-24.75 Y25 R0.25 Z-3.1299
    G01 X24.75 Y25 Z-4.3701
    G02 X25 Y24.75 R0.25 Z-4.3799
    G01 X25 Y0 Z-5
    G01 X25 Y-24.75 Z-5.6201
    G02 X24.75 Y-25 R0.25 Z-5.6299
    G01 X-24.75 Y-25 Z-6.8701
    G02 X-25 Y-24.75 R0.25 Z-6.8799
    G01 X-25 Y24.75 Z-8.1201
    G02 X-24.75 Y25 R0.25 Z-8.1299
    G01 X24.75 Y25 Z-9.3701
    G02 X25 Y24.75 R0.25 Z-9.3799
    G01 X25 Y0 Z-10
    G01 X25 Y-24.75 Z-10.6201
    G02 X24.75 Y-25 R0.25 Z-10.6299
    G01 X-24.75 Y-25 Z-11.8701
    G02 X-25 Y-24.75 R0.25 Z-11.8799
    G01 X-25 Y24.75 Z-13.1201
    G02 X-24.75 Y25 R0.25 Z-13.1299
    G01 X24.75 Y25 Z-14.3701
    G02 X25 Y24.75 R0.25 Z-14.3799
    G01 X25 Y0 Z-15
    G01 X25 Y-24.75 Z-15.6201
    G02 X24.75 Y-25 R0.25 Z-15.6299
    G01 X-24.75 Y-25 Z-16.8701
    G02 X-25 Y-24.75 R0.25 Z-16.8799
    G01 X-25 Y24.75 Z-18.1201
    G02 X-24.75 Y25 R0.25 Z-18.1299
    G01 X24.75 Y25 Z-19.3701
    G02 X25 Y24.75 R0.25 Z-19.3799
    G01 X25 Y0 Z-20
    G01 X25 Y-24.75 Z-20.6201
    G02 X24.75 Y-25 R0.25 Z-20.6299
    G01 X-24.75 Y-25 Z-21.8701
    G02 X-25 Y-24.75 R0.25 Z-21.8799
    G01 X-25 Y24.75 Z-23.1201
    G02 X-24.75 Y25 R0.25 Z-23.1299
    G01 X24.75 Y25 Z-24.3701
    G02 X25 Y24.75 R0.25 Z-24.3799
    G01 X25 Y0 Z-25
    G01 X25 Y-24.75
    G01 X-24.75 Y-25
    G01 X-25 Y24.75
    G01 X24.75 Y25
    G01 X25 Y0
    G01 Z3
    G03 X29.5 Y-4.5 R4.5
    G40
    G01 X34 Y-4.5
    M5 M9
    M30
    Try that?
    Keith
    Banned
    Jan 2006
    Seattle
    Thumbs up The code is good.
    Kipper,
    I ran your code through Vericut. Worked like a charm.
    Attached Thumbnails Attached Thumbnails Tool bit offset-verify-1.jpg   Tool bit offset-verify-2.jpg   Tool bit offset-verify-3.jpg
  1. Changing tool diameter in the tool offset screen
    By Vern Smith in forum Haas Mills
    Last Post: 09-24-2008, 10:54 AM
  2. Tool Offset (G45,G46,G47,G48)
    By jorgehrr in forum G-Code Programing
    Last Post: 11-13-2007, 02:54 AM
  3. Tool offset ...
    By patrickb in forum Fanuc
    Last Post: 08-21-2006, 11:53 AM
  4. Tool Offset
    By 3rdcoast in forum Mach Software (ArtSoft software)
    Last Post: 05-19-2006, 02:08 PM
  5. Tool offset input
    By Mircea in forum Machine Problems, Solutions , Wireless DNC, serial port
    Last Post: 05-28-2004, 07:16 PM
