Results 1 to 9 of 9
Thread: rapid travel
    Nov 2007
    rapid travel
    I finally got my BP with the Microkinetics drive working w/ the breakout board . Everything works except the rapid positioning (G0) which does not work. I tried everything that I know of but no dice. Any suggestions?
    Thanks Vinnie
    Jan 2004
    Bellingham, WA
    Quote Originally Posted by iccirvr View Post
    Thanks Vinnie
    doesn't work in a program? MDI? Both?
    Nov 2007
    It doesn't work in both
    Mar 2003
    Shelby Twp, MI....USA
    Is your code using G0 (zero), or GO (letter "O")?
    Nov 2007
    I use the zero not the letter
    Jul 2005
    Double check your mach settings
  7. #7
    Nov 2007
    I just went to my mill and double cked w/ a g00 x5 y3 MDI and it goes to location but at milling speed. I have been fooling aroung w/ my motor tuning and decreased the # of steps to as low as 500 from 2500 and no change.
  8. #8
    Mar 2003
    G0 speed is the speed set in the motor tuning. If you want it faster, increase the velocity in the motor tuning.
    Changing steps/unit will change the distance traveled, you shouldn't be changing it if you want your parts the correct size.
  9. #9
    Jan 2004
    Bellingham, WA
    Not sure if it would have anything to do with it, but if you open the MPG thingy (TAB key) what does your "Slow Jog" say?
  1. X3 X-axis travel mod
    By pzzamakr1980 in forum Benchtop Machines
    Last Post: 03-30-2008, 03:28 AM
  2. Int 412 shuts off on rapid Z axis travel
    By Jurek in forum Bridgeport and Hardinge Mills
    Last Post: 12-10-2007, 10:55 PM
  3. Have ballscrew will travel/how far?
    By lgalla in forum Linear and Rotary Motion
    Last Post: 01-10-2007, 09:39 PM
  4. Alarm (103) code in rapid travel
    By Michael Esch in forum Haas Mills
    Last Post: 09-22-2006, 06:53 PM
  5. Travel To Russia
    By moNkaD8 in forum Australia, New Zealand Club house
    Last Post: 08-16-2006, 09:16 AM
