Results 1 to 7 of 7
Thread: Mach3/madCAM, mill feed rates,homing, and scaleing
    Mar 2008
    Hello, I have a few problems that you guys can help me out on since I'm still a novice.
    1. What should I set my feed rate as in madCAM when making the G code for cutting plastic/machinable wax? I tried changing it from 11 to 50,100, and 500 all of which showed very little increase in speed. What are the units for the feed rate?
    2. When I click GOTO Z to go home, it homes the X and Y axis and then the Z. I hadn't thought about it until I clicked home after a test engraving and it put a nice groove across my work. haha. Is there a setting to change that?
    3. For some reason, I can't get the mill to make the correct size part. Not even within 25%. Example. I draw a pocket in rhino3d that is 1" by 1", extrude it down .1". Then I make the tool path and then the g code, load it into mach3, and run the code. the pocket comes out to about .25"x.25" square. What are all the settings I need to change?
    TaylorN.
    Registered teamtexas's Avatar
    Aug 2007
    check out this trouble shooting video http://www.machsupport.com/Videos/Ma...elections.html. It has a easy way to set up your machine for proper sizing.
    Good Luck
    Dan
    Mar 2008
    Well, I got the feed rate to work for me. But I'm still having problems with homing and scaling. I thought that since my board is set up for 1/8 steps, that something was wrong in mach3, so I scaled the drawing up 8 times in rhino and it made the part bigger, but still not the right size.HELP!!!
    Jun 2003
    Send me a pm with your email address and I will try to help. Don't want to do it here on the open forum.
    Mike
    No greater love can a man have than this, that he give his life for a friend.
    Mar 2008
    Ok, doing some research and thinking, I think I need to set my steps per unit (inch) to 32000. I'm using a xylotex 4 axis board set to 1/8 steps or 8 microsteps or whatever it came set as ( anyone know), and 1.8 degree xylotex stepper motors. I did the motor tuning wizard or whatnot in mach and it said 32000 steps per unit. When I tried to jog the motors, they just stalled. Am I wrong on the steps or something else.
    TaylorN.
    Mar 2003
    Shelby Twp, MI....USA
    What kind of screws are you using? 32000 steps per inch would be for 20 turn per inch leadscrews. The steps per unit have nothing to do with stalling. You need to lower your acceleration, and possibly your velocity as well. What are those set to, and what kind of machine is this? What size are the motors?
    Mar 2008
    Yeah they are 20 tpi screws. Its a taig mini mill. I'll try changing the acceleration and velocity at 32000 steps tommarrow. I cant tell you what those are set to right now because the mill is at my CAD class at school. The motors are xylotex 269 oz.in.
    TaylorN.
    1. Feed rates?
      By Rainman229 in forum G-Code Programing
      Last Post: 02-23-2007, 12:47 PM
    2. Feed rates & IPM
      By ChristopherWood in forum WoodWorking
      Last Post: 10-30-2006, 04:08 PM
    3. Mach 3 Mill feed rates
      By Ed_R in forum Mach Mill
      Last Post: 04-18-2006, 01:41 PM
    4. Feed Rates
      By rcheli in forum Benchtop Machines
      Last Post: 12-28-2005, 11:34 AM
    5. Rpm and Feed Rates
      By Xeno in forum General CAM Discussion
      Last Post: 02-23-2004, 05:06 PM
