Page 1 of 2 12 LastLast
Results 1 to 12 of 14
Thread: 3 axis mill retrofit
    Registered beezerlm's Avatar
    Oct 2005
    Hello
    I have a 3 axis machine with a junk anillam control. It has 3 SEM mt30m4-59 servo motors. http://www.sem.co.uk/files/brochure/MT30M4.pdf.
    I called Gecko and they said they didn't have anything that could drive these motors to the full capacity. Does anybody know an affordable solution? My power supply is 115VDC.
    I plan on using a CNC4PC c11 BOB and mach 3 to control this system.
    Help is appreciated!
    Brandon
    Jan 2006
    Try www.LarkenCNC.com they have a 180 volt servo driver.
    Oct 2005
    http://www.larkencnc.com/viper/v200.htmThanks! found it http://www.larkencnc.com/viper/v200.htm
    Question: My motors have a 9.5v per 1000rpm tach. Can I use linear glass scales for position feedback and eliminate the tach?
    Jan 2006
    WV
    No you must replace the tac with encoders on the motrors or the machine will "hunt" and tear up the ball screws.
    Happy Hunting
    archie =) =) =)
    Quote Originally Posted by beezerlm View Post
    Feb 2007
    uk
    try rutex
    could try this http://www.rutex.com/us/home/index.htm
    they do a 200v 40a drive , there is also a good pdf of how to match a drive to a motor.
    good luck
    Registered DennisCNC's Avatar
    Aug 2005
    Clearwater, FL US
    I'm no expert on Rutex but I haven't seen any posts by people running rutex drives. I have Viper 200 drives on my Bport mill and running good in the testing stage still working on the retrofit.
    Dennis
    Jan 2006
    WV
    I hear they are not as stout as they claim they are either. I plan to use the larkin drives as well on my boss retrofit (servo machine)
    archie =) =) =)
    Quote Originally Posted by DennisCNC View Post
    Oct 2005
    purchased viper 200's and us digital 500cpr encoders. Talked to Larry at Larken and he told me to use a Breakout board that is not opto-isolated becase the drives are opto-isolated. He said it could hurt the timing on your setup. Can anybody elaborate on this?
    Feb 2007
    uk
    I have heard the same thing about doubling up on opto's , The latest bob campbell combo breakout board ver 5 is not opto'ed on the step and dir. outputs .
    The description on his site is of ver2 and say's it is opto'ed but the site is behind the times ,the boards that he is shipping is ver 5 and is not, he says he is going to update the site.
    Oct 2005
    I have a CNC4PC C11 board and it is fully opto'ed. Any way to get around this issue?
    Feb 2007
    uk
    I have a couple of the cnc4pc boards but i am not sure what version they are, but they are only opto-isolated on the inputs, the outputs are just buffered .
    You may have a different version!!
    May 2006
    Can you let us know how this turned out? I have the same servo motors and am trying to do the same conversion. Any part numbers for encoders or pictures would be appreciated! Thanks.
  • Page 1 of 2 12 LastLast
    1. Lagun 3-Axis Retrofit
      By millnturn in forum Knee Vertical Mills
      Last Post: 09-24-2010, 02:28 PM
    2. BP S1 Z axis retrofit
      By CNC OT in forum Bridgeport and Hardinge Mills
      Last Post: 09-05-2007, 04:42 PM
    3. x2 retrofit x axis question
      By h_2_o in forum Benchtop Machines
      Last Post: 02-03-2006, 12:15 PM
    4. Looking to retrofit a Mill
      By the_0utsid in forum CNCzone Club House
      Last Post: 11-15-2005, 03:07 AM
    5. Retrofit: Central Mach. CNC 3 axis Mill
      By Rekd in forum General Metal Working Machines
      Last Post: 02-06-2004, 05:19 PM
