Your Y axis is setup backwards. Check the "reversed" box in Config>Homing/Limits. Then reconfigure you home/limit switches to match.
I give up Cant figure out why my part is displayed upside down on the tool display screen. When I try to adjust it something else changes,like in the homing/limits screen. Ill try to give link to a picture so you can see what I mean. Or if someone would please give me your settings, Its on a Syil SX3 mill. Thanks for any help!
I think I got it ! Thanks Brian
I have a similar problem. When I switch between "tool" and "table" the table had the work upside down. The table homes where I want it and cuts properly in the tool display. Just when I switch to table its upside down. I have tried to reverse the axis but it then either homes or travles the wrong direction. I can not figure how to set my limits. I have individual home switches that work great. James
