| Does Anyone No What Cam Program To Use With The Tp-100 Touch Probe So That I Can Change My Text File Of The Coordinates That Have Been Saved From The Probe Into A Viewable 3d Model Which Can Then Be Put Into Mach 3 For G Code Generation.i Heard Rhino Might Do This But I Was Looking For A Lot Cheaper Program As I Will Not Use The Probe That Much Anyway.i No It Works With Deskcnc But I Would Prefer To Use Mach3 As My Controller. Thanks. |
Mach3 can NOT generate g-code from a 3D model. You'll need another CAM program for that. Look at MeshCAM or Cut 3D.
| Gerry actually the probe txt file that Mach creates can be used for a gcode, if the tip of the probe and the diam of the cutter are the same....and you do a bit of editing on the txt file to set up the parameters. With that said, and if I read his post right, he is actually asking what progam to use to be able to make use of the point cloud and this of course will fall under cad instead of cam. Then again, I was wrong once before! Mike
__________________ No greater love can a man have than this, that he give his life for a friend. |
| touch probe and Mach3 | devincox | Mach Mill | 13 | 02-15-2010 08:58 PM |
| witch CAD/CAM software with MACH3 ?? | rontron | Mach Mill | 4 | 12-18-2009 01:38 PM |
| Probe software | paptep | Haas Mills | 18 | 07-31-2007 10:40 AM |
| DynaMite 2800 & Mach3 software | ffulmer | Mach Mill | 2 | 07-02-2007 04:12 PM |
| probe with mach3 | Don C | Mach Software (ArtSoft software) | 1 | 01-05-2006 09:19 AM |
