Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Mach Mill
Old 08-18-2007, 10:26 AM
RMT RMT is offline
RMT is on a distinguished road
Question Spindle takes 15sec to come on
This seems to be one more thing that I'm having trouble with , when clicking on start spindle or calling M3 in a program, it takes about fifteen sec before the relay in the breakout board gets activated and the spindle starts to run.
Yet the cooland comes on emidiatly, when M8 is in the code, what would be the reason and how do I change the spindle delay.
Frank
Old 08-18-2007, 10:40 AM
pointcloud's Avatar
Prototyper
pointcloud is on a distinguished road
There are setting in mach for spindel. Look in the mill options. There is a delay and spin up delay, they are normally milliseconds.
Hey check out my website...www.cravenoriginal.com
Thanks Marc
Old 08-18-2007, 05:55 PM
RMT RMT is offline
Yes under General Config>Spindle Setup there are 4 delays which all were set to 1 and I changed to 0 still about 15 sec delay.
I'm using the Campbell Designs all in one breakout board maybe that is for some reason delaying the output to the spindle.
Any other place in Mach 3 that would cause a delay?
The really bad thing is when You run a program the spindle comes on when its about finished with it..... not good.
Frank
Old 08-18-2007, 08:37 PM
Switcher's Avatar
Moderator
Switcher is on a distinguished road
Is it possible to swap the connections from the coolant relay with the spindle relay, & run the same g-code you have been trying, just to see If the spindle will start faster (you said the coolant relay was working fine) might help narrow down the problem?
Old 08-19-2007, 08:00 AM
pointcloud's Avatar
Prototyper
Look in Mill Options too...
Also check here http://www.artsoftcontrols.com/forum These guys can help, for sure.
Thanks Marc
Old 08-19-2007, 08:17 AM
RMT RMT is offline
I think switching cooland and spindle sounds like good idea, I will defenitly try that , the campbell board has led's on it to visually show when the relay's are active, and that led's comes on late too, so I thought the input must be delayed hence I was looking for the problem in mach 3.
Old 08-19-2007, 08:49 AM
Switcher's Avatar
Moderator
Have you looked at the settings (Mach3) in the attched screenshot?
Old 08-19-2007, 08:50 AM
mactec54 is on a distinguished road
Hi RMT
If everything else fails put a Dwell G04 for the time you need in the Program after the M3 or a M00 and when the spindle is up to speed press start again
Pressing start again is only for the M00 Can be as M0 if your control likes it
This will get you going I think the M00 is the easyest as you get a second
chance to check before the machine moves
Mactec54
Old 08-20-2007, 06:01 PM
RMT RMT is offline
I solved the Spindle problem by moving the connections to the dir output relay and resetting things in mach3 , the instructions are a bid confusing on the campbell board and there must be some mistakes, since it lists pin 1 for the spindle run relay and encoder ground, wonder why it come on at all.
I like to thank everybody for helping me figure this out
Frank
Old 08-20-2007, 09:28 PM
Switcher's Avatar
Moderator
Glad you got it working, I was planning on getting that B/O board.
Sweo spindle drive? new mill dead spindle Shizzlemah Fadal 13 12-18-2008 11:11 AM
interact 4 spindle drive won't turn on spindle 0041601 Bridgeport and Hardinge Mills 7 06-23-2008 05:51 PM
Lathe spindle bearings and spindle material mackeym Linear and Rotary Motion 1 08-11-2007 10:53 AM
TL1 takes up the slack gearman Haas Lathes 1 06-24-2007 09:30 AM
system takes more time to display the data karanindia Fanuc 0 01-25-2007 01:30 AM
