Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Mach Mill
Old 07-31-2007, 05:32 PM
frankg521's Avatar
frankg521 is an unknown quantity at this point
Homeing
Hi..... I have two motors running my x axis, when i home the x axis, one motor goes one way and the other motor goes the opposite direction
both are set to active low, I'm thinking i have to change direction of one motor but i need help with the wiring see attached pic
Frank
Name:	phase wireing.jpg‎
Old 07-31-2007, 05:36 PM
Dennis Bohlke's Avatar
Dennis Bohlke is on a distinguished road
Reverse B- and B+ wires to one motor.
The motor will now spin in opposite direction.
Dennis
http://www.super-tech.com
Old 07-31-2007, 06:11 PM
frankg521's Avatar
thanks
Hi Dennis thanks ill try that... the machine runs fine carriage jogs fine but when i home the x axis motors move in reverse
Frank
Old 07-31-2007, 07:07 PM
ger21's Avatar
Under Config>Home/Limits, is "Home negative" checked for one?
Old 07-31-2007, 07:12 PM
frankg521's Avatar
Hi Gerry... i think ive read all you posts.... i was hopeing you would respond
and yes "Home negative" is checked for both x and A... A is a slave
Frank
Old 07-31-2007, 07:16 PM
ger21's Avatar
How about in General Config, "Home slave with master"?
Old 07-31-2007, 07:17 PM
ger21's Avatar
Also, does each side have it's own switch?
Old 07-31-2007, 07:21 PM
frankg521's Avatar
Cant seem to find General Config???? and limits and switch only on one side
