Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Mach Mill
Old 06-24-2007, 12:41 PM
sweckard is on a distinguished road
Mach 3 with Mastercam X "Radius to end of Arc" error
I am getting "Radius to end of arc differs from radius to start on Line #" error when I import my g-code into Mach 3 from Mastercam X. This error only occurs when I have a contour tool-path after a simple drill tool-path. When I have contour tool-path ahead of simple drill tool-path, mach3 runs fine with no error.
I have both Mach 3 and Mastercam X set to Incremental for the I J Codes.
I am using postprosser from http://cnc.novalab.org/mach_files.htm
Attached is the part in mastercam x , the two differnet g-codes(one that works(Contour ahead of simple drill), and one with the error(contour after simple drill).
Thankyou.
Name:	mach3 error.jpg‎
Old 06-24-2007, 03:42 PM
ger21's Avatar
I'd ask on the mach3 support forum or Yahoo group.
Old 06-24-2007, 09:02 PM
Eurisko is on a distinguished road
Does the program indicate which line generated the error?
I looked at the error program, the only thing that looked odd was a series of axes moves after the G80 line. Maybe the control didn't default to G00 after canceling the canned drilling cycle?
Old 06-25-2007, 08:06 AM
ger21's Avatar
Line N270, which looked OK to me.
Old 06-26-2007, 07:29 PM
It is line N270 that is causing the error. And you are right Eurisko about the program not defaulting to G00 after canceling the canned cycle. I was able to fix it by reinstating G00 after the G80. Do you of a setting/post pross. that I could change in Mastercam X so it will reinstate G00 after G80. Thankyou for your help.
Old 07-05-2007, 10:23 PM
sweckard,
You're welcome. Always glad to help.
I'm not familiar with Mastercam, but there should be a way to create a custom macro using the G80 code.
Sounds like a good topic for a new thread. Please let me know what you find out, I may check out Mastercam when my router is finished!
p.s. sorry about the late reply, I've got to check these threads more often...
Old 07-06-2007, 07:43 PM
mark c's Avatar
mark c is on a distinguished road
add this line after G80 as shown below:
"G0", pfzout, e
pcanceldc #Cancel canned drill cycle
result = newfs (three, zinc)
z = initht
if cuttype = one, prv_zia = initht + (rotdia/two)
else, prv_zia = initht
pxyzcout
!zabs, !zinc
prv_gcode = zero
if cool_zmove = yes & (nextop=1003 | (nextop=1011 & t<>abs(nexttool))), coolant = zero
#if sdrnote = sdr07, "", e
# else,
"G80", e
"G0", pfzout, e
#if tapflg = 1, ""
tapflg = 0
That should work. It works on V9.1
Insanity "doing the same thing and expecting a different result"
Mark
www.mcoates.com
mori seiki mv junior "jog rset" error Arsonist General Metal Working Machines 10 03-24-2010 06:45 PM
"Runtime error 9 - subscript out of range" on Techno CNC interface zhoudfoster General CNC (Mill and Lathe) Control Software (NC) 4 10-25-2009 10:57 PM
V2XT error message "DRIVE FAULT detected (0,z,y,x) check log" rfdoyle Bridgeport and Hardinge Mills 4 10-08-2007 03:35 PM
I cant get Mastercam to output "I" and "J" Jeff S Mastercam 12 03-27-2007 05:12 AM
Changing radius from "R" to "L" values russell67 Post Processor Files 2 01-18-2006 02:02 PM
