Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Mach Mill
Old 06-22-2007, 11:19 PM
Green0 is on a distinguished road
Stupid problem - jogging incremental Mach 3 mill
I can't figure out how to make set incremental jog movements.
It's not covered in any tutorial I've seen, and unlike Mach3 turn, I have apparently NO incremental jog controls, so at present I just jog close with my keyboard, and then have to use G-code lines to step incremental.
If someone could help that would be great. It doesn't makes sense - it has to be in there somewhere.
Setting tools at present would be a complete WHORE.
Old 06-23-2007, 05:39 AM
hindocarina is on a distinguished road
After you hit the tab key to bring up the jog window, there are buttons on the window for switching between continuous and incremental jog. Just above those buttons there is a button for setting the jog increment. You can customize the increments in the main config window.
There are handy shortcut keys for the above actions. With the jog window open: cntrl + J = change from continuous to incremental; alt + J = change jog increment.
Charlie
Old 06-23-2007, 02:50 PM
I wasn't aware of the Tab key.
Thanks. Hopefully that will solve the issue.
Confused: Mach Turn, Mach Mill, Mach 2/3 ? CanSir Mach Software (ArtSoft software) 5 02-16-2007 04:41 AM
Motor jogging problem MagTDK DIY-CNC Router Table Machines 1 08-20-2006 03:26 PM
Jog problem with Mach 2 jtriggs Mach Mill 0 06-15-2006 12:48 AM
Jogging problem dmgdesigns Mach Software (ArtSoft software) 1 10-21-2005 03:08 PM
mach 2 problem CNCadmin Mach Software (ArtSoft software) 5 01-16-2005 02:12 PM
