Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Mach Mill
Old 06-18-2007, 11:21 AM
Involute is on a distinguished road
"Unspecified failure"?
When I try to set the spindle speed on my Syil Super X3 with M03 S1500 or M04 S1500 (whether from the MDI screen or in a part program), I get this error: Error on line 2 - Unspecified failure, and Mach3 presents a VB debug screen for the DoSpinCW or DoSpinCCW routine (though it only shows the name of the routine, no code). Needless to say, the spindle doesn't move. What might be causing this? Thanks.
Involute
Old 06-18-2007, 01:57 PM
P Riedie is on a distinguished road
Sounds like the XML file isn't setup for the machine and is missing something from either the M6 macro or the pulley settings.
Does Syil supply an xml file for their machine with it ?
PR.
Old 06-18-2007, 02:33 PM
Yup, and I should have said I was able to control the spindle from Mach3 when I first set the machine up a couple of months ago. I didn't think I'd changed anything substantive on the PC, but maybe I have unknowingly. The PC is dedicated to controlling the mill.
Involute
Old 06-18-2007, 02:56 PM
Is it really M03 S1500 and not got a capital O in there ?
Very easily done.
Failing that try deleting the Mach3mill.xml file [ or better still renaming it to mach3mill.old ] and then install the one that came with the machine.
PR.
Old 06-18-2007, 11:31 PM
It is M03 and not MO3, though the 0 is optional. In any event, looks like closing and re-starting Mach3 solved the problem, for now.
Involute
"low end" HF Spindle or "high end" router for about $1000? biomed_eng DIY-CNC Router Table Machines 14 01-06-2012 12:15 AM
Unspecified failure message Chrisjh Syil Products 14 07-04-2007 07:57 AM
Has anyone looked at the "JET" or "Shop Fox" manual machines? boosted General Metal Working Machines 12 03-04-2007 09:33 PM
Vertical system "jerks" and "bangs"?? REVCAM_Bob Servo Motors and Drives 5 06-12-2006 09:09 AM
Add "View New Posts" to "Main Menu" Mr.Chips Forum Questions or Problems 4 04-21-2004 10:54 PM
